It is currently Sat Oct 24, 2026 12:47 am
Post Posted: Thu Jan 15, 2009 4:32 am
hi every one just thought id post up some pics of my home made draws that i have been makeing over the last week for me sierra
first i got a metal frame made with draws on runners in side to make it easier and stronger
he draws have marine carpet in them which can be easly removed if needed for cleaning etc thay are held in with edging around the top
than i made a base and made mounting points useing the old seat bolt holes
than put the draws in and sentered every thing
cheked the draws dident hit
than made side panels for the front
black coily, 30 inch tyers, 2 inch suspention, 2 i
Post Posted: Thu Jan 15, 2009 4:36 am
dident get any pics of the top on without carpet
heres the base painted and carpeted and bolted to the flore
put the draws in and centered than screwed them down
carpeted the sides at front
and at the back
Post Posted: Thu Jan 15, 2009 4:41 am
hers the top on and carpeted with storage compartments at the side
hers the front without carpet
with carpet
and with handls
Post Posted: Thu Jan 15, 2009 4:45 am
hears the looks i used
dads fridge slide
and with the fridge
i take the fridge and fridge slide out when im not using them
cheers scott
Post Posted: Thu Jan 15, 2009 8:23 am
thats awesome mate. I'v realy wanted to make one of these but never had a good idea about how to go about it.
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Thu Jan 15, 2009 11:07 am
Agrred. That is very good. Would like to make something like that myself, but then there'd be nowhere for my daughter to sit.
Vehicle: MY2019 Jimny
Post Posted: Thu Jan 15, 2009 1:18 pm
What's wrong with sitting at home with her mother?
Awesome drawers mate, what did they cost you all up?
Last edited by lump_a_charcoal on Thu Jan 15, 2009 4:18 pm, edited 1 time in total.
Post Posted: Thu Jan 15, 2009 2:39 pm
the phrase "Master Craftsman" comes to mind. 10/10!!
Post Posted: Thu Jan 15, 2009 2:57 pm
:goodjob:
Vehicle: LJ80
Post Posted: Thu Jan 15, 2009 8:28 pm
great job very neat!
Post Posted: Thu Jan 15, 2009 11:19 pm
great job. very professional. :goodjob:
Post Posted: Thu Jan 15, 2009 11:23 pm
Thats Ace you should do that for a living ,you could charge by the slab and still have room in that giant fridge :wink:
Post Posted: Fri Jan 16, 2009 1:40 am
that is the best and most descriptive post on rear draws that i have ever seen!! wicked job!! gives me the incentive to do mine properly.!!! good work!
Post Posted: Fri Jan 16, 2009 2:01 am
Wicked man! I've been thinking of doing some in the back of the vit too, this is inspirational LOL
Post Posted: Fri Jan 16, 2009 2:20 am
She's 20 months old and prefers to be seen in my $2500 Suzuki, not her mum's $50k crossover :)
Post Posted: Fri Jan 16, 2009 3:35 am
thanks for all the comments guys, im only 17 and these are the first ones iv made so i thought i didn't do to bad 8) i did do a bit of research of how the professional ones were put together and basically just copied the one i liked :)
hers a pic of the one i copied and the company dident mined, thay actually took me in and showed me it up close and gave me tips on how to do things, which was great.
cheers scott
Post Posted: Fri Jan 16, 2009 3:37 am
and yes the fridge dose look pritty big in the back lol its only a 40lt angle
Post Posted: Fri Jan 16, 2009 12:08 pm
who was the company let you have a look? thats worth a free plug for everyone that doesnt want to make one :)
Post Posted: Fri Jan 16, 2009 1:14 pm
it was http://www.offroadsystems.com.au/
cheers scott
Post Posted: Mon Feb 09, 2009 11:46 pm
thats the neatest job iv ever seen and at only 17. and your car is in exellent condition 2. looks like u do things with a good attitude and ull do well in life i can assure u. well done Scott.
Post Posted: Tue Feb 10, 2009 1:22 am
thanks mate for the kind words, i do believe in doing thing right the first time and i like it to look good to :D
cheers scott
Post Posted: Tue Feb 10, 2009 11:21 am
hey mate looking into making a set of these myself so if you dont mind i have a couple of questions.
What did you use to keep the carpet attached?
How is the draw assembly shell together, ie. spot welds or rivets?
Post Posted: Tue Feb 10, 2009 6:27 pm
hay mate the metal frame is held together with pop-rivets and its just flat gal steal folded to shape, i used contact adhesive glue, you can get it from hard wear shops ect but it is a bit pricey so it works out to be cheaper if you buy the bigger tin. just ask if your got any more questions mate im happy to try and help.
cheers scott
Post Posted: Tue Feb 10, 2009 6:34 pm
cheers scott
The sliding brackets make a big difference, where did you get the ones you used? They can be pretty pricey but I think it's one of those items it would be wort spending some coin getting decent slides.
Post Posted: Tue Feb 10, 2009 11:31 pm
hay damo i got them from the bloke who made the metal frame for me, im sure he would sell u them if thats all you wanted, thay hold 75kg per draw which is heeps, on his sight thay say there $65 per pr for 700mm long and $85 per pr for 1000mm long.
cheers scott
hers his website http://www.offroadsystems.com.au/
Post Posted: Tue Feb 10, 2009 11:50 pm
did you say you had the original draws custom made for that or did you buy them somewhere retail? where they expensive? is it hard to reach into the fridge at that hieght or is it purely for storage and it comes out of the car when in use? cheers jamie
Post Posted: Wed Feb 11, 2009 2:26 am
hay jamie, um i got just the metal frame made buy the obove link^^^ he makes them all the time for the draw systems he sells, but normaly there 200mm high and i got mine made 280mm high (i think :? ) so thay were classed as a custom job, you can also get one big draw instead of two like mine and it is cheaper, hell make anyone one any size you want, i also got my carpet of him at a good prise, he did a good deal for me cos my dad has brought 2 draw systems of him in the past, i made mine for half the prise it would have cost me to get them made, give him a ring if you want a quote.
the draws stay in the car all the time but dont take me long to take them out if i want (about 20mins) and the fridge is taken out unless im going on a long trip were it is needed and i can see in it just fine but my short mum cant haha all depends on how tall you are mate lol
cheers scott
Post Posted: Thu Feb 12, 2009 3:36 pm
could you please take a pic of it straight behind the seats to show what it looks like in there. i am thinking of angling mine and putting 6x9 speakers in there
Post Posted: Thu Feb 12, 2009 7:48 pm
are there wat your after?
cheers scott
Post Posted: Thu Feb 12, 2009 9:52 pm
perfect thanks!!
