It is currently Thu Oct 29, 2026 7:45 am
Post Posted: Wed Dec 07, 2011 4:45 am
what sort of seats can u put in a suzukie sierra i have been talking to a few people and one person says you cannot put any other seats in them but the stock seat and others say you can put any seats in them
Post Posted: Wed Dec 07, 2011 4:47 am
You can put any seat in there that will fit, but will have to be mod plated
Post Posted: Wed Dec 07, 2011 4:49 am
ohk it is only for my front seats cause got no rear seats so u say anything just need a mod plate
Post Posted: Wed Dec 07, 2011 4:52 am
Not just any thing. Alot of seats need alot of modifications to the seat rails. There are seats that will go in easy with not much work like swift seats, race seats
I wouldn't rely on my answer as I don't no much about this, But make sure your seats mounts are well done or they won't pass inspection
Post Posted: Wed Dec 07, 2011 4:55 am
ohk thanks for your help i m just trying to get my little beast looking good and the seats that are in it now are stuffed cause it is a soft top but the people b4 i got it didnt have a soft top so the weather got to them
Post Posted: Wed Dec 07, 2011 5:04 am
I stuck Suzuki Swift seats in mine. Cost me $200 and were very easy to fit. You will need a mod plate if you fit anything other than the original seats
Vehicle: '92 Sierra
Post Posted: Wed Dec 07, 2011 5:08 am
Make sure that you check how the person mod plating it wants the seats mounted prior to doing the work. Autotechnica Monza seats supposedly only need new holes drilled in the rails. I put some no name brands in mine and I had to make some adapter plates out of 8mm plate.
Just a heads up. Your car is already illegal with the back seats removed unless it was imported originally as a 2 seater or mod plated already to have the rears removed. Not that anyone seems to care that much but if you're looking at getting it road worthy'd it is something they may ping you for. Throw the rear seats back in for the inspection.
Post Posted: Wed Dec 07, 2011 5:19 am
i got it mod plated cause i was talking to someone and they said it was needed and i have it regested so it is ohk at the moment
Post Posted: Wed Dec 07, 2011 5:20 am
and the swift seat look good what sort of swift are they out of ?
Post Posted: Wed Dec 07, 2011 5:32 am
This one, 97 model:
Post Posted: Wed Dec 07, 2011 5:46 am
ohk cool thanks for the help i will go to the wreckers and see if they have any and did you have to take every think out like the rails that are on the floor or did you use the ones that were in the sierra
Post Posted: Wed Dec 07, 2011 5:49 am
You use the rails off the seats in your Sierra and just bolt the Swift seats to them. The passenger seat takes a bit of dicking about
Post Posted: Wed Dec 07, 2011 5:52 am
ohk cool thanks for your help mate cause mine are just a bit stuffed i will try get some pic up of my car so far
Vehicle: Coil Sierra
Post Posted: Wed Dec 07, 2011 9:14 am
remember to look for a GTI swift, standard swift and barina will fit, but if you want buckets they are only in GTI's. Some others that are a close fit are DC Integra, late model swift.
Post Posted: Thu Dec 08, 2011 12:14 am
I fitted the Honda DC5 Intergra's in mine. They are a nice seat but a few things to remember.... you need custom seat rails made (both sides) a mod plate and also the height of the seat is a few inches higher.
The Zooks of Hazzard
Vehicle: 94 Sierra QX JX
Post Posted: Thu Dec 08, 2011 3:33 am
I had to refit the back seats and belts into my soft topp SJ70 to pass the Blue Slip. The lap belts, flimsy rear end and lack of a roll bar (that had to come out for rego too) makes them the most dangerous seats I have ever seen in any car. Someone at the RTA should get back onto their common sense medication. Should never have been imported as a four seater.
Users browsing this forum: Google [Bot] and 309 guests
