It is currently Sun Nov 01, 2026 3:28 pm
Vehicle: Sj70 tintop
Post Posted: Thu Dec 08, 2011 4:00 am
1.3 carby. g13ba
havent touched the zook in a fortnight and im getting ready to chuck the petrol tank back in,
so i charged the battery and put it in, went to turn over the engine, nothing.
all the auxiliaries work, no fuses are blown. i tried 3 other batteries (one out of the coily thats working) tried jumper leads.
i can turn the engine over by hand so its not seized.
was running perfect a fortnight ago when i parked it up and dropped the tank.
im really stumped.
help me out as im moving house soon and need the wheels to get around in.
seized starter motor?
Sj70 tintop
Post Posted: Thu Dec 08, 2011 4:05 am
wiggle the solenoid trigger wire on the starter and check its connection
Lil Foot!
Post Posted: Thu Dec 08, 2011 4:16 am
its on there solid as a rock, im stumped, buggered starter? :blink:
Sj70 tintop
Vehicle: 4wd
Post Posted: Thu Dec 08, 2011 4:18 am
Does it click?
Watch out or you'll get sued.
nope, nothing,
Sj70 tintop
Post Posted: Thu Dec 08, 2011 4:32 am
Sj70 tintop
Post Posted: Thu Dec 08, 2011 4:35 am
Got power on start on the exciter wire???
Post Posted: Thu Dec 08, 2011 4:36 am
exciter wire?
Sj70 tintop
Post Posted: Thu Dec 08, 2011 4:39 am
joel wrote:
exciter wire?
The small gauge wire to the solenoid. The one I was talking about before. Try bypassing the original by disconnecting it and apply 12V to the terminal on the starter.
Lil Foot!
lil one on the starter.........
Post Posted: Thu Dec 08, 2011 4:50 am
JrZook wrote:
joel wrote:
exciter wire?
how can i get 12 volt down there?
forgive my retardedness.
Sj70 tintop
Post Posted: Thu Dec 08, 2011 4:55 am
joel wrote:
JrZook wrote:
joel wrote:
exciter wire?
Have to bridge a connection between the battery positive to that solenoid terminal. Easiest way would be the bridge where the battery connects to the starter using a piece of wire or screwdriver.
If that don't work try bridging the two large terminals on the starter with your screwdriver. Be prepared for a spark or two.
Lil Foot!
Post Posted: Thu Dec 08, 2011 5:06 am
yep didn that and a lot of sparks and the starter turns, but when i try with the key it wont, whats the problem?
p.s lotsa sparks.
Sj70 tintop
Post Posted: Thu Dec 08, 2011 5:14 am
Ing switch by the sound of it...
Post Posted: Thu Dec 08, 2011 5:52 am
Do you have a test light????
Or multi meter??
Post Posted: Thu Dec 08, 2011 7:34 am
ran a test light and exciter wire has power, seemed as though the solenoid on my starter was farked so me and paul (sogone) swapped the starter motor over with one he had and BAM! all fixed
cheers thanks fellas!
Sj70 tintop
Post Posted: Thu Dec 08, 2011 7:50 am
you let sogone near ya car with tools 8O
Post Posted: Thu Dec 08, 2011 7:52 am
If you can try connecting the battery directly to the starter with jumper leads see how the goes
Post Posted: Thu Dec 08, 2011 7:53 am
hahaha he is pretty tricky with the spanners when he hasnt got a gut load of beer hahaha
Sj70 tintop
Post Posted: Thu Dec 08, 2011 8:02 am
i have only seen him in drunk mode :lol:
Post Posted: Thu Dec 08, 2011 8:12 am
Put the car in 1st gear and rock the car so the motor turns over a little. Then try again to start. Might be a sticky starter?
Or get a hammer and using the wooden handle part give the solenoid a bit of a tap as well.
Just my thoughts :-)
Post Posted: Thu Dec 08, 2011 8:16 am
yeah i gave it a few hits but it wouldnt even click, ive had trouble with it being lazy every now and than, and now cause it hasnt run for a fortnight seems its packed it in.
put another starter in it and its all systems go!
Sj70 tintop
Post Posted: Thu Dec 08, 2011 8:19 am
Fit a relay.......... to the exciter....... :helloo:
Good work joel.
Post Posted: Thu Dec 08, 2011 8:31 am
im Fit and really excited....... :helloo:
?cheers mate but im spoken for.
Sj70 tintop
Post Posted: Thu Dec 08, 2011 8:58 am
3 way is an option.... :helloo:
Users browsing this forum: No registered users and 224 guests
