It is currently Wed Nov 04, 2026 10:02 pm
Post Posted: Thu Dec 08, 2011 10:22 am
Hey guys i got a leak in the Sierra coily. It's the black box in the passenger footwell below windscreen and in front and under glove box? Leaks water on footwell any ideas what to do?
Also if anyone could link to a guide to change cam and crank seals would be great :)
Thanks
Post Posted: Thu Dec 08, 2011 12:47 pm
I believe that's your aircon box thing. I'd be looking at the connection from ya heater box thing to it. The grill from just in front of ya windscreen blocks up and it fills and leaks. There is a good guide on how to fix this. Might be in the tech section. It's midnight here and I'm on my iPhone so do a search.
Post Posted: Thu Dec 08, 2011 11:07 pm
Okies thanks so pretty much clean out the window grill thingo and see if there is damage causing leak or if box is loose and yeah I shall search for it tonight.
Post Posted: Fri Dec 09, 2011 2:36 am
The only way to clean it really good is to pull the whole lot apart. I think alien found a real good web site with how to get around doing it. Basically using a hole saw cut a hole where the leaves build up, vacuum it out then use a washer a rubber grommet a nut a bolt an another washer to reseal it. Maybe some can remember the article. I can't fin it.
Post Posted: Fri Dec 09, 2011 9:44 am
Im still going to get some wire mesh and screw it down over the vents .At least it will stop leaves and other crap building up .
Post Posted: Fri Dec 09, 2011 9:56 am
i think this is the one sogone is talking about http://www2.izook.com/?page_id=258
Post Posted: Fri Dec 09, 2011 11:30 am
I vote ya change name to search-tari4x4
Post Posted: Fri Dec 09, 2011 11:35 am
i say get fucked, sorry i was just trying to help. :roll: :evil:
Post Posted: Fri Dec 09, 2011 11:51 am
What about Grimtari?
Post Posted: Fri Dec 09, 2011 12:04 pm
Bahahahahahaha. It was a compliment. :lol:
Post Posted: Fri Dec 09, 2011 12:07 pm
so is this :thefinger:
Post Posted: Fri Dec 09, 2011 7:18 pm
Thanks
Air con??????
Post Posted: Fri Dec 09, 2011 7:53 pm
It could even be the actual heater core.
But not telling us what type of water it is, when it happens etctetc, its not helping.
brown or green water, warm= coolant, heater core up to shit, buy new one.
clear but only after rain= blockage in heater core/vents( i blocked off the whole vents up top, stopped leaks forever!)
clear but only when aircon is on= aircon drain blocked.
Post Posted: Sat Dec 10, 2011 2:12 am
Hey sorry yes it was this one
clear but only after rain= blockage in heater core/vents( i blocked off the whole vents up top, stopped leaks forever!) so u reckon just block vents? but wont that stop the car aircon/fans from heating the car?
Post Posted: Sat Dec 10, 2011 3:24 am
The only thing it will change is the heater/vents won't blow air through from outside, with the fan off..
Not that you need the heater in summer, Many people have made up a plate that is easily removed if needed with nutserts in the body etc.
http://www.auszookers.com/index.php?nam ... light=vent
Users browsing this forum: Google [Bot] and 190 guests
