It is currently Sat Oct 31, 2026 1:09 am
Post Posted: Tue Dec 13, 2011 9:08 am
hi guys. trying to diagnose my front wheel not locking properly problem. its locks in when ya turn the hub to lock bt if ya hold the tyre with your hands and turn it when its jacked up you can rotater the tyre with enogh force. at first i thought it was jst turning where ya lock the hubs in but after doing it again im not sure if it was maybe turning inside the diff. its got a lockright in there.
cant check now really coz i have pulled the hub off down to where the axle is now exposed.
just wanna know what part is responsible for the locking in
Post Posted: Tue Dec 13, 2011 9:12 am
The knob you turn pushes in a hub gear that locks on another gear that is on the end of the CV.
Undo the little bolts and pull the front cap off, if its all in one piece i'd say you've done a CV/axle as per suggested in your last thread of the same thing.
Post Posted: Tue Dec 13, 2011 9:23 am
Doesn't a lockwrong only lock under acceleration, if that's the case turn you front drive shaft with the hubs locked and see what that does
Post Posted: Tue Dec 13, 2011 9:30 am
constantly locked , allowed to unlock easily without load (acceleration)
Post Posted: Tue Dec 13, 2011 9:31 am
not much with the wheels on the ground.
and spin the wheels with them off.
This is what i encountered with broken CV's. seems fine until a point, then slips as the CV expands.
Post Posted: Tue Dec 13, 2011 9:33 am
constantly locked under torque. the cross pins in the centre push open the locker and make it grab the side gears/couplers.
Post Posted: Tue Dec 13, 2011 9:36 am
ahk then I'm wrong. If your hub hasn't been pulled apart its unlikely won't be the hub not working. I'm with Dan. Broken axle/cv or broken lockright pins or some thing.
Post Posted: Tue Dec 13, 2011 10:06 am
ok thanks guys. what will a broken cv look like when i pull it out? will it be snapped or will it just look normal? im unsure how they work
Post Posted: Tue Dec 13, 2011 10:13 am
the stub could be snapped.
the axle could be snapped.
both of which will be obvious.
Otherwise the outer part will have a crack in it under inspection or the inner will have cracks in it, or chunks removed from it.
Post Posted: Tue Dec 13, 2011 10:22 am
this thread sounds familiar, as Dan said look at the CV's or axles. http://auszookers.com/index.php?name=Fo ... ic&t=28349
Post Posted: Tue Dec 13, 2011 10:26 am
this one is in regards to how the hub locks my friend. wanted to see if it was the hub spinning under force
Vehicle: Zookless
Post Posted: Tue Dec 13, 2011 10:30 am
This is what the inside of the hub looks like.
I reckon you should pull it apart and have a look :wink:
Post Posted: Tue Dec 13, 2011 10:35 am
ok i see how that works now. what is the next bit after the hub. that removes with 12mm (i think) bolts?
does the hub lock into that bit and thats how the locking happens?
Post Posted: Tue Dec 13, 2011 10:37 am
the cv and axle are 2 seperate parts are they or does it all come out in one part?
That whole bit does it. Its called a manual locking hub.
Vehicle: Zookless
Post Posted: Tue Dec 13, 2011 10:39 am
After removing the outer hub, you will have to remove a cir-clip from the axle. Then you can remove the 12mm bolts and then slide off the rest of the hub.
Get a screw driver to bend back the locking tabs.
Then you'll need a 50mm socket to remove the first nut.
Behind that will be the locking washer thing-o. Followed by another 50mm nut.
Post Posted: Tue Dec 13, 2011 10:41 am
ok. yer i gotta pull the next bit off tomorrow to get the cv out
Post Posted: Wed Dec 14, 2011 5:23 am
broken cv joint on the ring bit :(
anyone got one they can sell me asap so i can go out on the weekend. tried repco and driveshafts place at geebung
Post Posted: Wed Dec 14, 2011 5:26 am
ebay for like $50. just the joint though so you will need to put them on the axle.
Post Posted: Wed Dec 14, 2011 6:03 am
gold star for Dan :wink:
Post Posted: Wed Dec 14, 2011 6:48 am
getting one second hand off a guy. need it for the weekend to go up hills
Post Posted: Wed Dec 14, 2011 9:18 am
I've gone through 3 sets of CV's in the past two months or so, it was easy to pick :D
Users browsing this forum: No registered users and 366 guests
