It is currently Fri Oct 30, 2026 10:42 am
Post Posted: Fri Dec 16, 2011 7:44 am
Ok first off I have searched.
All the other threads are different to my car. With my vitara my rear brake set up is blocked by my hub.
By the looks of it I cannot get in to change anything without removing my axle. Is this right or am I not seeing the simple way?
Basically my car has a drum cover that falls off when the wheel is taken off.
Then my hub with 5 studs in it (obviously). Where everyone else's seem to have a small hub with 4 bolts in it.
Does anyone have pictures of my set up because I have no idea how it goes together.
Next question is, how do I remove the axle? I have tried turning the drum inside out and using it as a slide hammer but it doesn't work.
Any little tricks you can help me with?
Post Posted: Fri Dec 16, 2011 7:46 am
dont remove teh axle, you jsut need to harden up and get at it :)
its hard work but its how it is, PS when you remove the axle the brakes come with it
Post Posted: Fri Dec 16, 2011 7:53 am
Haha I'm way too soft. I have to do wheel cylinders aswell. So its gonna be near impossible. Or so it seems.
Royce, have you seen the set up I'm talking about? (No sarcasm intended)
Post Posted: Fri Dec 16, 2011 7:55 am
sounds like the same set up as mine, what are you trying to do?
have you removed the 4 nuts from the bearing retainer on the other side of the brake backing plates?
you can change the brake shoes with the axle in place.
umm we own the same model car, of course I have
most normal cars are similar, pull the shoe retaining pins first and jsut work at it one side at a time
Post Posted: Fri Dec 16, 2011 8:02 am
Yep took the nuts off and it still wont budge.
I need to do wheel cylinders at the same time. Is this possible?
They're fiddly and time consuming and a general pita!!
Post Posted: Fri Dec 16, 2011 8:03 am
That's right. Forgot about that.
Got a spare CV :)
Post Posted: Fri Dec 16, 2011 8:19 am
I made the royal mistake of having the handbrake on when I took the drum off. Now all the springs have fallen off and I have no idea where they go.
Even more of a pita
Post Posted: Fri Dec 16, 2011 8:21 am
Both sides?
Post Posted: Fri Dec 16, 2011 8:28 am
Just one side. I'll have to find a way to jack up the other side to have a look
Post Posted: Fri Dec 16, 2011 11:06 pm
Who would of thought it would he so hard to find brake shoes.
I have the awkward model that no one had heard of
Users browsing this forum: Google [Bot] and 341 guests
