It is currently Tue Nov 03, 2026 12:28 pm
Post Posted: Sat Dec 17, 2011 3:51 am
The box section is 50x25 2mm RHS. The plan was to slot the bottom out and weld the shock mount in along the bottom edge. Also to cut the RHS on an angle from the reaf bottom corner to where the top meets the axle tube. Then weld the lot to the housing.
The problem is that i'm starting to think the housing might be opened up along the welds. I Think what I should do is plate the housing, similar to how you'd plate a chassis before welding to it. 2mm flat bar should be heaps for the plating.
Post Posted: Sat Dec 17, 2011 4:04 am
thats a LOT of leverage on the diff housing!
what about doing it off the u-bolt plates and have the pin facing towards the hub? kinda like mine but turn it 180 degrees would have it in a similar position to what you have there SPUA.
Post Posted: Sat Dec 17, 2011 4:19 am
Make some gussets. once rhs is welded on, weld some gussets on the sides of it and make them wrap around the diff housing more.
Post Posted: Sat Dec 17, 2011 5:16 am
Why are they so long?
Post Posted: Sat Dec 17, 2011 5:27 am
I got a spare set I bought from LROR that I'm not using if your interested?
Post Posted: Sat Dec 17, 2011 5:44 am
same.
Post Posted: Sat Dec 17, 2011 6:23 am
diff going forward???
Post Posted: Sat Dec 17, 2011 7:31 am
Which ones are they? i'm interested!
The first pic was a little misleading, the mount doesn't need to stick out as far as it looks in that pic.
I cut the RHS down a bit and also trimmed the shock mount. I tacked it into place with the standard spring plate in plate as a comparison. I kinda think it will actually be OK without plating the housing, but would hate to tear the housing open.
If I plate it it'll have to wait to next week as I don't have any material on hand.
Pics of it mocked up:
Post Posted: Sat Dec 17, 2011 7:43 am
looks a LOT weaker than the factory one IMO... factory is clamped in with the u-bolts and has the perch to stop it twisting etc... yours relys on only a small amount of welding on the diff only.
Post Posted: Sat Dec 17, 2011 7:46 am
They are only shocks, they don't take all of the impact the spring would be taking most of the resistance.
helloo
Vehicle: Sj70 tintop
Post Posted: Sat Dec 17, 2011 7:47 am
what will be the advantage of this? will be handy if moving the diff forward, looks pretty cool.
Sj70 tintop
Post Posted: Sat Dec 17, 2011 7:49 am
true, but they take TONS of vibration and constant back & forward pressure, plus as the spring cycles the shock levers on the mounts too (even if the bushes absorb it, its still applying a twisting force).
Post Posted: Sat Dec 17, 2011 7:53 am
Doing a RUF conversion, Diff will be coming forward slightly.
Post Posted: Sat Dec 17, 2011 7:54 am
Might eventually break depending on his welding ability, either way it's a Suzuki it's ment to be broken and welded again hell look at my radius arm mounts
helloo
Post Posted: Sat Dec 17, 2011 7:57 am
im planning on moving my front diff forward, let me know how ya go on this.
Sj70 tintop
Post Posted: Sat Dec 17, 2011 7:58 am
ill be doing a write up once its done
Post Posted: Sat Dec 17, 2011 8:02 am
I reckon some flat that runs along your open angled section on the top and up over the diff tube some and the same underneath will take care of a lot of the bending force weakening the diff housing
Ive seen really strong and well tested shock mounts fail really quickly when under strain so they are under a decent amount of strain
Post Posted: Sat Dec 17, 2011 8:34 am
That will be fine damo. I used the same design on my ute for almost 2 years without a problem.
Post Posted: Sat Dec 17, 2011 8:43 am
Cool, I will bring it to you if it breaks :lol:
Post Posted: Sat Dec 17, 2011 8:44 am
hmmm talking about a car that hasnt moved in how long :)
Vehicle: Daisy
Post Posted: Sat Dec 17, 2011 8:45 am
So are you mounting these out wider or something? Why do you need to make new shock mounts? Couldn't you just modify the original plates?
I may have missed something here.
Post Posted: Sat Dec 17, 2011 8:51 am
If it's reasonably well welded it will be fine.
I'm doing a RUF conversion on a WT but moving the springs inboard to NT specs. So the upper mounts will be WT and the NT mounts will be NT. I am pretty sure that this will cause me some chassis clearance issues, hence why I want to move them out a little.
Vehicle: Daisy
Post Posted: Sat Dec 17, 2011 8:53 am
All good, was just wondering why you didn't have them in the original spot, I figured there was some WT+NT stuff going on.
Good luck with it dude! :)
Post Posted: Sat Dec 17, 2011 9:19 am
Thanks Steve. I was kinda assuming birdshit and Sikaflex weren't going to cut it this time :lol:
Now I have two people to blame if it tears the housing open i'm going to do it this way 8) 8O
Users browsing this forum: Google [Bot] and 69 guests
