It is currently Wed Nov 04, 2026 8:31 pm
Vehicle: 89 SWB vitara, g16b conversion
Post Posted: Sat Dec 17, 2011 10:29 pm
In the process of a carby to EFI conversion of an 89 Vitara.
Went to connect up the coil and connected to the bolt is this black square thing with two wires coming off it.
Both wires are black with no markings but the two it connects to from the loom are black, but one has a white line.
What is this thing?
And is it polarity sensitive, if so, which wire goes where?
Post Posted: Sat Dec 17, 2011 10:31 pm
Radio suppressor I think.
If both wires are black then it doesn't matter which way you connect them.
Post Posted: Sat Dec 17, 2011 10:45 pm
Correct in a way, it's used to keep the coil quite so the ecu can't hear it....
That lil black thing with the white plug..... don't lose that.... :wink:
Post Posted: Sun Dec 18, 2011 3:41 am
Cheers, so its not polarity sensitive though?
Post Posted: Sun Dec 18, 2011 3:49 am
No, if it was the wire's would be marked ( colored)
Black with white stripe is ing, I think the other side goes into the neg of dizzy pulse...
Just plug it in mate.... :helloo:
Users browsing this forum: Google [Bot] and 219 guests
