It is currently Wed Sep 23, 2026 12:01 am
Post Posted: Sun Dec 18, 2011 10:26 pm
Hi all, I have a 08 1.9 Turbo Diesel Grand Vitara
its started overheating on the freeway, it does not do it around town at all.
It does it randomly while on freeway temp will rise and aircond cuts out, then as you slow the temp gauge will drop aircond starts again, keep driving temp goes right up stays up aircond cuts out pull over temp drops down again ac works again drive off all fine.
also the thermo comes on when car is turned off and the coolant constantly circulats through the overflow bottle.
We did the thermostat so its not that, has anyone had this problem or have any ideas???
Vehicle: 75 Cruiser
Post Posted: Sun Dec 18, 2011 10:51 pm
something wrong with airflow in to the radiator? or waterflow through the radiator?
Post Posted: Mon Dec 19, 2011 5:26 am
have you changed you coolant lately????
Gen suzuki coolant's don't mix well with others.
Seen rad's 80% blocked from this.....
Post Posted: Mon Dec 19, 2011 5:37 am
If you mix coolant your pretty much buggerd after that potential to blow up your engine flush your radiator and heating system and clean it all and try again with new water coolant and stick to one in the future. all I use is castrol in both my cars can't get mixed up in the future then and I always have a spare bottle laying around
Vehicle: ute
Post Posted: Mon Dec 19, 2011 9:07 am
any black smoke under power? diesels get hot when they overfuel. if you didnt flush the cooling system when you did the thermostat do it now, was it overheating before the new thermostat? could it be in upside down?
as above dont mix coolants.
Post Posted: Mon Dec 19, 2011 10:37 am
My petrol Vitara was doing similar.
Mine was a faulty viscous fan hub.
Yours is not very old,
but worth a look,
assuming it has the same type of fan.
Post Posted: Tue Dec 20, 2011 9:26 am
i believe they have 2 thermo fans , dont get to see too many but im sure thats what they have
Post Posted: Tue Dec 20, 2011 7:59 pm
Hey guys so we gave up, car is now at suzuki there going to find out what it is then we're gonna fix it.
$115 just for them to look at it, the guy in there did say that they have had a lot of trouble with the diesel lately.
ill keep ya posted.
Post Posted: Wed Dec 21, 2011 5:11 am
They do, & they like to strip out the fan if you've driven through water with em on...
Vehicle: Suzuki Grand Vitara 08 diesel
Post Posted: Sun Apr 17, 2016 10:05 pm
Hi what was the outcome of this. I have the same car and have the same problem. Thanks Mel
Users browsing this forum: No registered users and 213 guests
