It is currently Mon Oct 26, 2026 11:29 pm
Post new topic Reply to topic  [ 415 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14  Next
Vehicle: Ex-Owner
Post Posted: Thu Dec 22, 2011 8:26 am
How much for the small plastic flap-lid thing which sits between the two front seats which covers a storage spot? Mine's busted and it's a little annoyance I want replaced :P
Mitch D.
Post Posted: Thu Dec 22, 2011 8:53 am
Not sure it has one. I'll look tomorrow and let you know.
Vehicle: Ex-Owner
Post Posted: Thu Dec 22, 2011 10:11 am
Cheers mate.
Also, would the steering wheel column cover-thing fit a '92 SWB Vit? Mine's suffering from major sun damage.
Mitch D.
Post Posted: Fri Dec 23, 2011 5:00 am
There is no lid thing and the column cover is stuffed.
Sorry.
Post Posted: Fri Dec 23, 2011 5:01 am
Engine, loom, ECM and power steer are all sold.
Vehicle: Ex-Owner
Post Posted: Fri Dec 23, 2011 6:12 am
Sorry.
Ah, that's a pity. Cheers anyways man.
Mitch D.
Vehicle: nt sierra
Post Posted: Sat Dec 24, 2011 6:07 am
hey mate
after some WT retractable seat belts. good enough condition to pass a Road worthy. and a quote to Vic 3074.
Post Posted: Sat Dec 24, 2011 6:18 am
86slowsierra wrote:
hey mate
Not sure I have any left.
Will look and let you know.
Post Posted: Mon Dec 26, 2011 8:34 pm
hey mate would you have a full power steering kit to suit conversion onto a 1988 1.3 sierra?
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
Post Posted: Mon Dec 26, 2011 8:39 pm
Sorry no.
Vehicle: 91 swb vit 5"lift 31's.
Post Posted: Tue Dec 27, 2011 6:46 am
hey mate got any ash trays for a swb vit? the ones in the dash infront of the gear stick under the stereo??
Post Posted: Tue Dec 27, 2011 6:47 am
Transfer case cross member
Post Posted: Tue Dec 27, 2011 9:21 pm
There is one here but it has some ugly phone holder glued to it.
Yep got one here.
Post Posted: Tue Dec 27, 2011 10:44 pm
i might pass haha what about all 3 locks for swb?? and possibly ignition barrel so i can keep the same key for all.. haha
Post Posted: Tue Dec 27, 2011 10:49 pm
Yep.. Ignition, glove box and 3 door locks are still here.
Vehicle: 93 lwb vitara
Post Posted: Wed Dec 28, 2011 2:02 am
do u have any good starter motors for a g16
Post Posted: Wed Dec 28, 2011 5:42 am
Sorry only got G13 starters left.
Post Posted: Fri Dec 30, 2011 2:38 am
hey mate got a good viscous hub on that vit? if so how much? cheers
Post Posted: Fri Dec 30, 2011 3:21 am
hey jas wouldn't happen to have a set of extractors and exhaust for a lwb vit
Post Posted: Fri Dec 30, 2011 3:28 am
It went with the engine/loom.
Had extractors but they went with the engine. Have a decent SWB system here that is complete with cat/con.
Post Posted: Fri Dec 30, 2011 5:04 am
Bit of a long shot but do you have any A frames that go on the front of a swb Vit so i can tow it behind my patrol.
Post Posted: Fri Dec 30, 2011 6:59 am
No....
You can't legally A frame tow a Vitara behind a Patrol.
You need a much larger vehicle (over 4500kg).
Post Posted: Fri Dec 30, 2011 9:36 am
Hi from what i understand from the transport department sheet called "safe towing".
Introduction
This section of the Queensland Transport website explains how to undertake "A" frame towing of a
motor vehicle with a Gross Vehicle Mass (GVM) of up to 4.5t in Queensland in a manner that satisfies the Queensland Road Rules.
Basically if the A frame has engineer approval and one set of the towed vehicals brakes must work when the towing vehicals brakes are applied and it is within the legal towing capacity of the towing vehical then it is legal.
Post Posted: Fri Dec 30, 2011 12:02 pm
So your not just after the a frame then mate your also after all the modified braking to suit too. I suggest you try some where that dose motor homes as this is the only time I've seen these set ups used legally and I'm sure they are worth a pretty penny too as for mounts I'm sure extra ones would be bolted on and engineeried
Your rims flipped from $50
Post Posted: Fri Dec 30, 2011 11:01 pm
Would you have an efi swb vitara fuel tank?
1990 Hardtop Sierra- Twin locked, 2" Spring lift,
Post Posted: Sat Dec 31, 2011 12:47 am
Sure do. PM sent.
Post Posted: Mon Jan 02, 2012 2:02 am
Any LWB Vitara fuel tanks?
Post Posted: Mon Jan 02, 2012 6:49 am
Do you have a 5.12 ring and pinion to fit into a sierra diff?
And postage to NSW 2446.
Post Posted: Mon Jan 02, 2012 6:52 am
exhaust manifold and cat for a j20a?
Post Posted: Mon Jan 02, 2012 7:10 am
:no:
yess!! PM sent.
:no:
Users browsing this forum: Google [Bot] and 171 guests
