It is currently Tue Nov 03, 2026 11:26 am
Post Posted: Fri Jan 06, 2012 10:49 pm
Didnt get much Buildup pics of this as it was fairly quick to make up.
So Basically, The plastic bottom section of the front bar of my MK1 shape Jim was poo. Front chassis hoop points were a mess and ripped off. So, Make some stonger 4wd ones!
Cut the old shit flat chassis mounts off. Mark out some holes to drill. Some people might want to crush tube the chassis, I didnt, I just welded 4 m12 nuts on the inside of the chassis, a side.
Bar is made up of 2off 100x5 flatbar and the side edges/hoops are 8mm?from memory?
Basic pics to get an idea. A winch could be added for a stock look if wanted.
This makes the plastic bar abit flimsy, as its only then held on with plastic clips and 2 screws at either end in the guards. Depending if you care, Some small brackets can be made to hold the bottoms of the bar. It would stop alot of the movement.
Post Posted: Sat Jan 07, 2012 9:09 am
I got snatched off of this bar. It's so simple and neat, I didn't even notice it at first.
Post Posted: Sat Jan 07, 2012 9:16 am
nice fabwork once again, i'm impress/jealous as always. :thefinger:
i think my new years resolution is to learn to weld properly. :oops:
Post Posted: Sat Jan 07, 2012 9:21 am
mig, gas, steady hand and patience is all you need.
Post Posted: Sat Jan 07, 2012 9:26 am
i've got 2 of the 4, reckon the last time i welded anything was 98 or 99. welded a fair bit in high school + the cortina resto's, i'm sure i'll pick it up again, but it's been a while. :lol:
Vehicle: 4wd
Post Posted: Sat Jan 07, 2012 9:28 am
Is it possible to have a steady hand after all those bongs :?
Watch out or you'll get sued.
Post Posted: Sat Jan 07, 2012 9:39 am
steady as a rock.... i just checked, although i don't think i've got a pulse. 8O
Vehicle: 4wd
Post Posted: Sat Jan 07, 2012 9:40 am
:lol:
Post Posted: Sat Jan 07, 2012 9:41 am
One of the better welders I've ever met is usually 10 cones in before he even starts welding.. :lol:
Post Posted: Tue Jan 10, 2012 1:33 am
Nice job on the recovery bumper thingy. I like!
LOL
