It is currently Mon Oct 12, 2026 8:27 pm
Vehicle: LPG 1.6 Sierra
Post Posted: Sat Jan 07, 2012 8:36 am
Hi guys. What's the best way to get silicon off? A previous owner has gone a bit crazy with the stuff along a couple of seams, but want to get it all off so I can lay a bit of paint down
Post Posted: Sat Jan 07, 2012 8:50 am
use hammertone paint.
problem solved
Post Posted: Sat Jan 07, 2012 8:52 am
scraper is the only way unless you want to use some really badass chemicals...
http://www.selleys.com.au/sealants/silicone/remover
Post Posted: Sat Jan 07, 2012 9:07 am
problem solved
fish eyes in a can, spray painters worst nightmare :lol:
i'm no painter but, i'd clean it up as much as possible, prep the area, wash it with prepsol/wax n grease remover & hope for the best or go back to bare metal. pretty sure there is a silicone type additive that you can get for contaminated cars that you mix with the paint to stop the paint reacting with the silicone when spraying with a gun/compressor.
paging ajsr... :helloo:
Post Posted: Sat Jan 07, 2012 9:27 am
Not sure about Silicon, but I use Eucalyptus oil cleaning up Sikaflex. Works brilliantly.
2002 SWB GV
Lifted and Locked
Post Posted: Sat Jan 07, 2012 10:03 am
problem solved
plastic scraper (if you dont want to scratch shit) other wise steel is better
and then prepsol and your fingernail.
sometimes those pinstripe removal wheels work well to
silicone sucks balls and is for lazy fuckers
oh and for painting silicone drops stops fish eyes.
Vehicle: LJ20 LJ50
Post Posted: Sat Jan 07, 2012 10:07 am
high powered gerni
sand blaster
soda blaster
Petrol
Acid
That selleys stuff is basically petrol/acid mix in a gel
I am a tight arse so I would use my fingers as much as I can then rub with petrol, getting a terrible headache, then finish with acetone for the remants.
If you have a air compressor then you could soda blast it.
Camels have nice toes
Vehicle: 1995 soft top vitara
Post Posted: Sat Jan 07, 2012 10:56 am
give some carby cleaner a go, that stuff is good for everything
turbo vitara, fark yeah.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Sat Jan 07, 2012 11:34 am
i imagined 50% caustic soda in a paint sprayer... that would strip anything, including all the aluminium within 500m. glad to see its only baking soda!
Post Posted: Sat Jan 07, 2012 12:12 pm
you can buy a rubber wheel that fits in your cordless drill, doest effect paint at all, i used it to take of glus from a jet ski matt, couldnt believe how easy it was, depending on how much ther is i would try an eraser just to see how it goes
Post Posted: Sat Jan 07, 2012 1:42 pm
I use a wire wheel mounted in the drill or the sand blaster ($30 from Supercheap, you'l need a good air compressor though!).
Post Posted: Tue Jan 24, 2012 1:38 pm
dusting the silicone affected area with plaster dust will allow you to paint over it without fish eyes... doesnt do much for the gloss level though.
Vehicle: 2004 SQ625 GV
Post Posted: Tue Jan 24, 2012 10:22 pm
Wire buff wheel
Vehicle: '92 Sierra
Post Posted: Tue Jan 24, 2012 11:19 pm
Sand blasted a swingarm with a sticker on it back when I wasn't so sharp (16) and I had a permanent embossed sticker outline as it chewed the metal around it but did not a lot to the sticker. Does this not happen with the silicon?
Post Posted: Wed Jan 25, 2012 2:01 am
YEP. You cannot blast silicone off metal with sand or soda.
Users browsing this forum: No registered users and 278 guests
