It is currently Thu Aug 06, 2026 5:33 am
Post Posted: Wed Jan 11, 2012 12:07 pm
the air vents in the center of my dash are loose.. is this a common problem? and can i just pull them straight out??? i plan on "shimming" the contact part with some modelling plastic to make them "tight" again..
Post Posted: Wed Jan 11, 2012 12:10 pm
My jims were loose.
Post Posted: Wed Jan 11, 2012 12:31 pm
can you heat up the plastic and "stretch" it to make it tighter??? that worked for one of mine
Post Posted: Wed Jan 11, 2012 12:42 pm
yeah mine does that on one so guess it's a little common.
mine has the older square type vents.
when it's hot it's tight but when you put the air-con on ond it cools down it gets loose.
chewy wrapper work a charm
Post Posted: Wed Jan 11, 2012 2:04 pm
same happened to mine, I just bought one of those little adhesive carpet-ish thingys that u buy to put like under furniture to not scratch the floor, painted black with a marker and put it on top of the vent so it create nough friction in order to make them steady..... much better than the trick of folding a little piece of paper till is thick nough for the gap lol :lol:
:helloo:
Post Posted: Wed Jan 11, 2012 6:33 pm
I put a repco receipt in mine.... Ace!
Post Posted: Wed Jan 11, 2012 7:25 pm
I had a business card in mine. Was very faded after a few years of direct sunlight.
Post Posted: Wed Jan 11, 2012 10:40 pm
as a piece of paper is the more popular choice I would say it must be better!
Post Posted: Wed Jan 11, 2012 10:41 pm
VVT Jimny vents are much better :D
Post Posted: Wed Jan 11, 2012 11:03 pm
aww...
maybe!
you could put a vvt dash in your jimny!
problem fixed :D
Post Posted: Thu Jan 12, 2012 12:13 am
yeh but in my fix u dnt see the paper, they look like factory :P
Post Posted: Thu Jan 12, 2012 2:24 am
i know... i'm just being lazy :(
Post Posted: Thu Jan 12, 2012 2:34 am
:helloo:
I've done very similar but with a single side adhesive foam..
even became a factory fix for a rattle in the Jb's center vent's.... :P
:helloo:
Post Posted: Thu Jan 12, 2012 3:29 am
fixed. moddeling plastic, black paint and some superglue
Vehicle: 99 Dirty Green Jimny
Post Posted: Thu Jan 12, 2012 9:48 pm
haha there is a fix for everything around here, now how about when the (structural) paper falls behind the vent, ive got a few sitting there!
Post Posted: Fri Jan 13, 2012 8:23 am
Yeah i had the same issue. Business card did the trick but i like the sticky felt idea.
When i installed my fm and uhf radios i found a heap of business cards in behind the dash....so someone else had the same idea.
Mitch.
Post Posted: Fri Jan 13, 2012 9:12 am
pompoms pompoms
Only issue with my A/C is when i turn it on sand and dried up mud come out vents :( :lol:
Users browsing this forum: Google [Bot] and 343 guests
