It is currently Thu Oct 29, 2026 10:08 am
Vehicle: Jimny M18A,Twin locked lift
Post Posted: Sun Jan 08, 2012 10:01 am
My zook needed more go, so I made a manifold and added a set of 4 X 31mm CD Mikuni carbs from a 650cc suzuki Katana. I used a 1000cc suzuki air box as I respaced the carbs to be inline with inlets in the head.I didn't run pod filters because they require to much rejetting to make them work. Clean air is via a corolla airbox. The cooling system is a custom block using the 2 original head outlets via some 3/4" heater hose. The engine fired and ran well straight away, but was a little rich. A rejet down from the 110 to 102.5 netted an overall increase from 29kW(bog stock at 196,000km) to 47kW with extractors as well. The fuel consumption is only marginally lower. The carbs have been on for over 12,000 km now and have been tested on the Birdsville track with no issues. Even got the zook up Big Red on the edge of the Simpson Desert. Driveability is excellent including up steep inclines. The idle mixtures are still a bit rich, so I will sort that out soon as the motor does over fuel on long downhills, with a closed throttle. The carbs stay in tune very well and have only been balanced on initial set up. Pictures attached
Post Posted: Sun Jan 08, 2012 10:18 am
8) x 5267899212569
Post Posted: Sun Jan 08, 2012 10:26 am
nice install 8)
Post Posted: Sun Jan 08, 2012 11:06 am
coolness factor 565876589765 bazillion 8) 8)
more pics
Vehicle: Jeep
Post Posted: Sun Jan 08, 2012 11:50 am
Awesome !!! 8) :woohoo:
Post Posted: Sun Jan 08, 2012 12:13 pm
The only way that would be cooler is if it was on an LJ50. :P 8) 8)
Vehicle: Jeep
Post Posted: Sun Jan 08, 2012 12:21 pm
Haha... i just had a thought, this setup would be great on a 1.6L Zook engine, oh yeah ! :D
Post Posted: Sun Jan 08, 2012 12:27 pm
i wanna see a youtube video of it to hear what it sounds like =D
Post Posted: Sun Jan 08, 2012 12:35 pm
Would be awesomer (minus one carby of course) on 539cc of ring ding fury! :P
Post Posted: Mon Jan 09, 2012 6:09 am
Sorry Alien, The induction roar has been lost inside the aircleaner somewhere! Removing the air box(which has neat ram tubes as standard) makes some noise , but the bugger wont rev. The standard CD carbs need to suck through a fairly small opening to work properly. (learnt this from a mate who is a motorcycle mechanic) The bike airbox fits around the mastercylinder giving a "factory option" look anyway. Even the inlet elbows and tubes are standard sierra items. As a comparison we did a back to back dyno run with a 2006 Jimny. He made 44rear wheel kW against my 47r wkW. Old school still works! I am going to need a new motor soon as 6000 r/min can't be good for an old donk. Maybe a G16 plus carbs?
Post Posted: Mon Jan 09, 2012 6:27 am
g16b has more webbing on the block to help stop it cracking, but if you're going to find a g16b you might as well use the EFI that comes with it.
Post Posted: Mon Jan 09, 2012 8:03 am
You are right! Do I admit to being an atuo electrician at this point? I should have done a GTI conversion with all the EFI, but I have always wanted to do a quad carb set up, and I had access to all the bits from years of Jap bike ownership so the conversion was not expensive.
Post Posted: Mon Jan 09, 2012 8:18 am
Do you know nandor? There is an uncanny resemblance, to him with a quad carbed sierra and jumping up a mound at what looks like morgan :lol:
Vehicle: Ducati Monster
Post Posted: Mon Jan 09, 2012 8:44 am
hmmmmmm might have to keep the eyes open, i really like this idea, had an LH torana years ago with triples & they were awesome
Post Posted: Mon Jan 09, 2012 8:48 am
I reacon these would stay tuned better and longer and be more efficient that damn triple webbers :evil: I loath tuning those fucking things!!!
Post Posted: Mon Jan 09, 2012 8:51 am
This can be sorted by playing with the air bleeds in the vacuum slide as well as the slide spring rate and needle heights etc.
Response would be awesome with the quads!
Lil Foot!
Post Posted: Mon Jan 09, 2012 9:16 am
good times mate good times, they were wicked just after a tune, but a nightmare to get just right, had some great days with the old man tuning em together though.......
Post Posted: Mon Jan 09, 2012 9:30 am
50% increase from carbs and exhaust? got dyno print outs?
Post Posted: Mon Jan 09, 2012 10:43 am
Maybe you should pick up a spanner or screwdriver instead of telling them how purrdeeee they are.
Vehicle: Jeep
Post Posted: Mon Jan 09, 2012 11:49 am
I think that if you do go EFI, you will have no shortage of people with there arms up, waving cash, to get that quad carb set up ! :wink: :lol:
Post Posted: Mon Jan 09, 2012 6:04 pm
Sweet talking went out the window quickly with the stupid things :twisted:
Post Posted: Tue Jan 10, 2012 12:49 am
Royce, I will post up the dyno sheets when I get back to work. All the runs are using the same dyno and the same operator. (a Mainline Dyno used for our performance and tuning course at TAFE) The original run @29kw was done for a laugh with some students. The extractors and 2" system added 6kw (35kw), the unjetted carbs made 40kw, and the final run saw 47kw after jetting. The car now makes the same power at 3400 r/min that it did at 5500 r/min stock. It will run at 110kph easily, but has best economy at about 90kph. All internals of the engine are also stock at this stage, so major carby performance upgrades where not needed.
Post Posted: Tue Jan 10, 2012 3:12 am
Have you played with the timing on the dyno yet with these carbs?
Lil Foot!
Post Posted: Tue Jan 10, 2012 5:01 am
i'd be skimming that head to bump the comp up 3/4 of a point, i reckon that should see ya another 10kw if not more
Post Posted: Sun Jan 15, 2012 12:58 pm
i've seen good results from a quad carb setup on a GTi 1.3L engine, that would make a screamer in a sierra.
Post Posted: Sun Jan 15, 2012 9:58 pm
hey mate how much for one of these in a 'plug and play situation'?
what did you have to do with all the old vacume lines?
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
Post Posted: Sun Jan 15, 2012 11:10 pm
The next step up from this would be bike quad throttle bodies. I had a set i was gonna use abut got a case of CBF. The corola carby was working good enough for me.
The quads i got had 2 injectors in each throat. One for low end and another that kicked in at higher revs. That would have been wicked in a Sierra.
Vehicle: 92 Suzuki Sierra
Post Posted: Sun Feb 26, 2012 1:48 pm
-Santos
Post Posted: Sat May 05, 2012 9:13 pm
The carbs are still working fine, really hassle free. included are the dyno run overlays.
Post Posted: Sat May 05, 2012 9:48 pm
Now that's a nice comprehensive dyno analysis! Power and thus torque are increased throughout the whole rev range with the carbs and exhaust. Would be very practical for offroad use!
Modman: Did you also play with the timing on your dyno runs to optimize it?
Lil Foot!
Users browsing this forum: No registered users and 21 guests
