It is currently Thu Oct 29, 2026 9:12 pm
Post Posted: Wed Jan 18, 2012 10:47 am
i have found some ok rims for my gv
http://www.tirerack.com/wheels/results. ... cial=false
prob go the machined look
now they only come in +10 offset whats your thoughts on that?
Post Posted: Wed Jan 18, 2012 10:52 am
Nice 8)
Post Posted: Wed Jan 18, 2012 10:59 am
what about the offset that still confuses me noend ?
Post Posted: Wed Jan 18, 2012 11:04 am
think the offset will cause you some problems, pretty sure the XL-7's rims are -5's?
being +10 they're going to sit closer to the chassis rail/struts etc.
Post Posted: Wed Jan 18, 2012 11:09 am
damn so cheap too
Post Posted: Wed Jan 18, 2012 11:10 am
whats the offset i should ask for ?
Post Posted: Wed Jan 18, 2012 11:15 am
I reckon they would look much better with my alloy front diff housing so I can swap diffs just to help you out :wink:
That is bucketload of stupid questions, not cash!
Post Posted: Wed Jan 18, 2012 11:28 am
Post Posted: Wed Jan 18, 2012 11:40 am
ive tried to get my head around that but ???\
my tyres only rub because when i bought it it came with 235/75/16
am fitting new 225/70/16 soon but i want to keep the track with the same as i have now,with stock rims with a 50mm spacer i cant find one person to tell me what my current offset is ?
Post Posted: Wed Jan 18, 2012 11:45 am
The inside edge of the rim will sit about 17-18mm closer to the chassis thanks to the +5mm offset and extra rim width over standard XL7 rims.
You need a -7 wheel if you are wanting to use 16x8's. This will maintain the same inner bead to chassis clearance that you have now. Best to ask for -10's.
Post Posted: Wed Jan 18, 2012 11:52 am
Pretty sure a 225 is considered too narrow for a 8" rim. Even a 235 might be stretching it a little, would make it quite easy to roll beads at low pressures I would imagine.
Are you really running 50mm wheel spacers? That seems like a hell of a lot.
I've looked at getting mags for mine before but there really is stuff all out there in a 16x7, and as I want to stick with 235s I dont want to go up to an 8" rim.
Moses' SQ625 GV Pig
Post Posted: Wed Jan 18, 2012 12:03 pm
wheel spacers are 1 inch
i was told my factory gv rims are 16x8
now im realy realy confused
Post Posted: Wed Jan 18, 2012 12:05 pm
if it's got the original XL-7 rims on it, open the drivers door & have a look at the tyre placard, will give you the rim width.
Users browsing this forum: Google [Bot], winchzook and 403 guests
