It is currently Mon Oct 05, 2026 12:20 am
lesspostingmorewheeling
Post Posted: Sun Feb 08, 2009 8:55 pm
is there a safe way to weld up a hole in a fuel tank?
cheers
Mike
Post Posted: Sun Feb 08, 2009 9:07 pm
yep, fill it up with water a few times and then get the
apprentice to chuck a match at it to make sure it is ok to weld.
Post Posted: Sun Feb 08, 2009 9:14 pm
Drain and clean the tank really well then purge it with co2.
It can be done but there is always a risk.
I have seen a motorcycle smash repairer do bike tanks by sticking a big hose in the tailpipe of a running car then the other end in the tank and let in run for half an hour or so.
I would still cringe when I saw him wave the oxy torch over the filler of the tank.
Post Posted: Sun Feb 08, 2009 9:18 pm
fill it up with water and wel the hole up with the tank still full (if possible, that is if the tank can be sealed so the hole isnt under water)
Post Posted: Sun Feb 08, 2009 9:32 pm
As ball said, the proper way is to purge with an inert gas.
The theory is that with no oxygen a fire (and subsequen t explosion) can't occur. I cant remember what flow rate is recommended, but you calc how long to leave it fill (capacity/flow rate), and leave it a little longer just for safety factor. Have the gas flow continue while you weld to ensure all the oxygen is displaced.
I have done a tank repair once before, I filled it with water. I think the water thing is not recommended because water + electricity = potential hazard.
Post Posted: Sun Feb 08, 2009 10:51 pm
is there an inert gas that is heavier than air so it will 'fill' the tank?
Post Posted: Sun Feb 08, 2009 11:10 pm
CO2 is heavier than air.
Post Posted: Mon Feb 09, 2009 1:08 am
Yeah you can buy it from your local BOC or you can try Argon as well
Vehicle: 1999 Jimny
Post Posted: Mon Feb 09, 2009 3:08 am
Just chuck some dry ice in it....... simple.
Post Posted: Mon Feb 09, 2009 3:27 am
I took mine to a fabrication place & had it steam cleaned. Cost me about $40 to have it done. I later found out a mate could have done it for free by taking it to his place of work... Damn him!
Vehicle: LJ20 LJ50
Post Posted: Mon Feb 09, 2009 3:33 am
expanding on this idea
take out the sender unit and turn the tank upside down. pump a little air in through the pick up so this way any heavier than air hydrocarbon vapours will float out the hole. Do this over night. then turn on its side with the hole ( damage ) to the bottom and the filler and sender hole as high as it can be then drop some dry ice pellets into the tank. this will help purge the tank.
the trouble is the hole will be on the bottom and the you will want the hole to be on top so its easier to weld. this way any heavier than air gases will fall out the filler neck or sender unit hole. Capping these holes is not a good idea to trap the gas in.
also dry ice pellets will cause the metal to be at minus 78.5 c which if heated rapidly and then cooled rapidly will affect the strength of the steel.
Camels have nice toes
Post Posted: Mon Feb 09, 2009 3:55 am
co2 is the go as argon is expensive
Vehicle: LJ20 LJ50
Post Posted: Mon Feb 09, 2009 4:01 am
Nitrogen is cheap too and is more effective.
Post Posted: Mon Feb 09, 2009 10:40 am
if you place a cup full of dry ice pellets in the tank submerge them in around a 1L of water, will cause it to break down alot quicker and will give more gas to purge the tank
Post Posted: Sat Feb 14, 2009 2:17 am
Flush with water till no fumes then use large sordering iron and solder hole is a lot safer than welding it.
91 hardtop 30" ,2"springs, 2" body lift
Post Posted: Sat Feb 14, 2009 2:23 am
Vehicle: 75 Cruiser
Post Posted: Sat Feb 14, 2009 2:24 am
yeah too much over analyzation with this gas shit. Just wash it out with water a couple times as shepo said, throw some flames around and you'll be let down because it won't catch fire. then just weld it.
Post Posted: Sat Feb 14, 2009 5:58 pm
Just welded up a crack in mine. Rinsed with water and left open in the sun for two days. Threw a match in for precaution, nothing happened, so happy welding.
Dan
Post Posted: Sat Feb 14, 2009 7:03 pm
all i do is fill the tank up with fuel, rub the crack with a rag
to get it really clean and then jam a bit of metal epoxy in the crack.
the stuff i use is called kneedit and it seals and sets no problems.
leaking tank fixed in a few minutes.
Post Posted: Sat Feb 14, 2009 7:21 pm
Bush mechanic style :roll:
Post Posted: Sat Feb 14, 2009 10:56 pm
fill it with argon and purge weld it!
Web wheeler extroadinaire
Post Posted: Sun Feb 15, 2009 3:03 am
keeps the fuel in but.
Post Posted: Sun Feb 15, 2009 3:18 am
doesn't have to hold it in for long the way your suzi drinks it 8O
Vehicle: 1999 Jimny
Post Posted: Sun Feb 15, 2009 5:23 am
If you are in the bush the good old sunlight soap works as well, rub it into the crack & it will seal it for a few days, long enough to get you home. ( That's if you fellas have any soap... :P )
Post Posted: Sun Feb 15, 2009 11:54 pm
I have a feeling none of them wash :gross:
Post Posted: Mon Feb 16, 2009 2:05 am
Cmon, we know you chicks love that manly smell :P
Users browsing this forum: No registered users and 190 guests
