It is currently Tue Aug 04, 2026 7:10 pm
Vehicle: 89 SWB Sierra (soft top)
Post Posted: Mon Jan 23, 2012 4:11 am
are they?
Post Posted: Mon Jan 23, 2012 4:12 am
no
Post Posted: Mon Jan 23, 2012 4:18 am
damn
Post Posted: Mon Jan 23, 2012 4:44 am
yes and no..
same center (with in reason) but diffrent ratio
Post Posted: Mon Jan 23, 2012 5:22 am
Jimmey, you need to know what you are asking.
When you say "diff centre" do you mean this whole bit:
Because that's normally known as the "third member"
WT and NT are interchangeable but not the same - as has been pointed out, ratios are different. WT - 3.7, NT 3.9. The driveshaft flange also has a different bolt size and pattern.
Or just this bit:
Which is the actual diff centre.
Rear WT and NT diff centres are the same.
The front is different - NT used the more desirable 4 spider gear centre (like a rear) whilst WT used a less desirable 2 spider gear centre.
Again, interchangeable, but not the same.
Post Posted: Mon Jan 23, 2012 7:16 am
Okay before every one confuses every one
Nt 1l is different to wt 1.3 and nt 1.3l(won't interchange)
Nt 1l ratio is 4.1 I think not 100% sure
Nt 1.3 is 3.9 ratio and will interchange with wt 1.3l
Wt 1.3 is 3.7 ratio and will interchange with nt 1.3l
I'm talking about third members
Post Posted: Mon Jan 23, 2012 8:02 am
1.3 NT and WT thirds and Centres are all interchangeable. Difference will be ratio and flange bolt pattern.
I've also found that there are different spline types on the pinion/flange.
Some WT flanges slip straight on a NT 3.9 pinion and some that do not.
One spline type had more of a square shaped spline the other was more triangular.
Users browsing this forum: No registered users and 281 guests
