| Author |
Message |
stonedpirate
Joined: Mon Dec 28, 2009 10:30 pm Posts: 231 Location: Australia, perth
 Posted: Tue Jan 24, 2012 10:33 am |
Hello,
Just spooted a great jimny with ARB winch bullbar.
Since i am only interest in beach and road driving and wont be doing anything in the outback or deep bush, is a bullbar recommended?
I heard the weight like 70kg and you need new suspension up front to stop them from leaning forward. Is that true?
Would putting more weight up front make it perform worse on deep soft beach sand?
Also, would i ever need to use the winch on the beach? Might be useful for dragging large sharks up when fishing but other than that, would there be a situation on the beach where i would need it?
Or would a lighter the better approach be better for a beach car?
All info is greatly appreciated
Thanks
Bucketload
Joined: Sat Feb 12, 2011 11:34 am Posts: 236 Location: Perth
 Posted: Tue Jan 24, 2012 10:38 am |
Mate, if you like the car buy it and if you don't want the bar I'm sure you can jump on here and someone will give you their bumper, fit it for you and give you some cash on top for the bar. In theory any way
_________________ That is bucketload of stupid questions, not cash!
Fatzook
 Posted: Tue Jan 24, 2012 10:42 am |
IMO the lighter the better, but will you really notice the extra 50kg's?
monley
Joined: Wed Nov 24, 2010 7:58 am Posts: 11092 Location: Mandurah.W.A.
 Posted: Tue Jan 24, 2012 10:49 am |
Fatzook wrote: IMO the lighter the better, but will you really notice the extra 50kg's?
I didn't notice the extra weight on mine
Also they don't weigh 70KG  more like 25-35kg
_________________ Tell my arse, he actually gives a crap!
Mike57
Joined: Fri Jul 22, 2011 11:09 am Posts: 1009 Location: Melbourne
Vehicle: Suzuki Jimny 2009
 Posted: Tue Jan 24, 2012 10:50 am |
Removing the front bumper and replacing it with something else is a good idea probably even for beach driving. It greatly improves the approach angle and eventually you will probably end up breaking the plastic bumper anyway and should consider some sort of modification.
There are also other ways to mount a winch without going the full ARB bull bar.
Yes, it does weigh something like 50kg or so (not sure if it is 70kg so check with ARB on that). Yes it will add weight to your front suspension but you don't necessarily need to upgrade your suspension. 10mm spring spacers will fix any droop and since it is only a small amount of lift you won't risk full compression of your springs (like with a 50mm spring spacer).
I am not sure that the extra weight will affect beach driving but with a Jimny every bit counts.
I have the ARB bar and am very pleased with it and the way it looks but check out the other bar options that are lighter or just chop the front bumper yourself. Check out Zukenutter's build thread, he has done a nice job without using a bull bar.
Fatzook
 Posted: Tue Jan 24, 2012 10:53 am |
monkey wrote: Fatzook wrote: IMO the lighter the better, but will you really notice the extra 50kg's? I didn't notice the extra weight on mine Also they don't weigh 70KG  more like 25-35kg
With a winch? I think 70 would be about right.....
monley
 Posted: Tue Jan 24, 2012 10:55 am |
Fatzook wrote: monkey wrote: Fatzook wrote: IMO the lighter the better, but will you really notice the extra 50kg's? I didn't notice the extra weight on mine Also they don't weigh 70KG  more like 25-35kg With a winch? I think 70 would be about right.....
Maybe with a winch...but why would you need a winch on the beach?
BertZook
Joined: Wed May 26, 2010 3:01 am Posts: 2979 Location: Sunshine Coast
 Posted: Tue Jan 24, 2012 11:21 am |
naaaah that thing of "bullbars improve approach angle" is only for other 4wds
jimnys have a really good approach angle (and departure lol )
at least in the older bumpers.... the new model needs a chop chop
anywhoo, another advantage for having a bullbar on the beach is
1- recovery points.... (I know jimnys dnt get bogged), but when it happen, ull have a point to be snatched from
2- a place to put ur fishing rods..... donno wht kind of fishing u do, but if its on the beach I bet u re (or will be) using one of those loooooong rods in order to be able to trow ur lure far away over the waves thing...... those rods dnt fit into a jimny, so having a bar u can add some fishing rod holders so u can carry em from there up to the roof
3- other mounting places to put ur spotties (if u like to do some night fishing) and for the UHF antenna, u need it to drive on big beaches, or in order to call for help or to chat to others on how big was ur fish or where is the "spot" of the day
4- they look cool, and would make ur jimny look less gay
the winch, I donno.... depepnding if u wanna do some other kind of wheeling, but u can take it off and sell it here before it gets rusted by no use after years on the beach
_________________ "BertZook's Jimny needs mods fundraiser"
Benz
Joined: Mon Oct 27, 2008 10:30 pm Posts: 1006 Location: Cervantes WA
 Posted: Tue Jan 24, 2012 12:28 pm |
nah you will be fine on the beach with a bar.
it wont make a noticeable difference.
keep it for the recovery point option.
drop they tyres to 10 psi keep the revs up above 3k for soft stuff and you will go just about anywhere
atari4x4
 Posted: Tue Jan 24, 2012 12:35 pm |
good spot to mount spotties, UHF antenna & a good spot to mount a fishing rod holder.
tonka_tuff
Joined: Mon Jul 06, 2009 11:30 pm Posts: 1017 Location: brisbane QLD
Vehicle: 91 swb vit 5"lift 31's.
 Posted: Tue Jan 24, 2012 2:39 pm |
the winch would come in handy if you were wheeling on the sand on your own and got megggaaaaa stuck and couldn't dig.. you could just winch,use your spare as an anchor..
jimny_timmy
Vehicle: Suzuki Jimny 2010
 Posted: Tue Jan 24, 2012 7:13 pm |
Arb bar is 60kgs. Didn't really notice the difference till I putthe winch in. Even then, I still get up sand dunes most large 4x4s can't.
got_bar_work
Joined: Sat May 15, 2010 8:30 pm Posts: 2214 Location: Brisbane
 Posted: Tue Jan 24, 2012 8:41 pm |
Imo if u drive anywhere out side of the city u need a bull bar
More for animal strikes then anything but all the other things can put on them are a good point
Microwire
Joined: Tue Oct 12, 2010 12:40 am Posts: 543 Location: Casula
Vehicle: Vitara 90'
 Posted: Wed Jan 25, 2012 12:48 am |
MrRocky
Joined: Thu Dec 17, 2009 10:30 pm Posts: 4731 Location: perth
 Posted: Wed Jan 25, 2012 1:36 am |
I dont like the extra weight over my front tyres, the last big 4x4 i had the the bar was so heavy it took 2 of us to move it and i can lift a sierra diff comfortably on my own. Just seems to make the front end less responsive and lurch about more. Have had a few near misses and done a shitload of outback driving, as long as your not doing 100 clicks at night time then generally your pretty right.
_________________ ...
zukenutter
Joined: Sun Feb 08, 2009 10:30 pm Posts: 9045 Location: Brisneyland
 Posted: Wed Jan 25, 2012 5:52 am |
if you need a winch on the beach you've done something very wrong. Personally I'm not a fan of steel bars but if its already got one I'd say keep it. As Bert said, great place for hanging stuff.
_________________ Click WWW below for STICKERS
stonedpirate
 Posted: Wed Jan 25, 2012 6:13 am |
yeah, i guess it looks cool too
I am going to attach a sling shot to it to launch baits into the sea with a handline.
Summer shark fishing will be sweet.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Wed Jan 25, 2012 6:38 am |
There is no advantage or need in a bullbar for many 4WD's, let alone a car that's used primarily on road/beach.
The weight over the front wheels is not insignificant and will reduce capability on sand with no other obvious gain.
Benz
 Posted: Wed Jan 25, 2012 7:20 am |
Gwagensteve wrote: There is no advantage or need in a bullbar for many 4WD's, let alone a car that's used primarily on road/beach.
I saw no change...
Gwagensteve
 Posted: Wed Jan 25, 2012 7:24 am |
That doesn't mean the effect isn't real. ANY additional weight is a disadvantage, and not just in sand.
Benz
 Posted: Wed Jan 25, 2012 7:35 am |
meh i guess so.
it's not that bigger deal though...
have been in and witnessed situations where a winch was a huge help on the beach.
was once stuck on a stupid angle on a dune which caused my fuel to run to one side of the tank and staved the jimny of fuel.
was quite a arse clenching experience.
winching from the top of the dune was the only safe way to straiten the car on the dune as any pull from below would of pulled the car over.
guess you could of done it with a snatchy but would of been a little risky with the sudden sideways forces involved
but i still wouldn't buy a winch for beach work in a jimny
Liljim
Joined: Fri Apr 16, 2010 11:30 pm Posts: 94 Location: Ballarat.
Vehicle: Jimny!
 Posted: Wed Jan 25, 2012 9:14 am |
Mine sagged down a bit when i fitted my ARB, It annoys me a bit, but I did $1400 worth of damage to one of my old cars by hitting a wallaby (it hopped away) so I'm going to put spacers in to correct the sag, I"d rather a chopped bumper a la zuknutter though...
The bullbar definitely improves approach, I measured it with a stick.
abclarke
Joined: Mon Feb 14, 2011 8:19 am Posts: 1966 Location: Couridjah
Vehicle: 1985 Holden Drover
 Posted: Wed Jan 25, 2012 9:15 am |
stonedpirate wrote: yeah, i guess it looks cool too
Anyone else notice how this guys posts all relate to looking cool or not looking gay?
_________________ 1989 WT Sierra.
