| Author |
Message |
bailey08
Joined: Fri Oct 23, 2009 10:30 pm Posts: 257 Location: Brisbane North
Vehicle: 02 GV
 Posted: Thu Jan 26, 2012 4:26 am |
I noticed on my last Glasshouse run a few weeks ago that there was a clicking sound from the front of my 02 GV. after doing a search it sounds like my CV's.
I had a look at them today and the dust boots are in 2 pieces on both sides and looks like a fair amount of grease and crap in there after a bit of wheeling.
I have an AWN warranty which is great(they've replaced the ECU after jump starting and a starter motor, no questions asked at no cost to me).
So I can get the CV's fixed for free under the warranty but they're not stuffed, just clicking. The warranty also stats that CV boots are not covered which would be the cause of the CV's.
So I need them to be stuffed.
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Thu Jan 26, 2012 4:29 am |
So you want advice on how to break them?
You're a funny bloke.
Find a rock step or something you can't get up and get it bouncing.
_________________ mlm
atari4x4
 Posted: Thu Jan 26, 2012 4:34 am |
If the CV clicks it's stuffed & on it's way to being rooted, you'll just have to try & sell it to the warranty mob. the damaged boots will most likely be the cause, the CV is ment to have grease in it... not a combo of grease/dirt/mud/water.
MacDaddy
Joined: Thu Mar 26, 2009 10:30 pm Posts: 10453 Location: Perth, Australia
Vehicle: Jeep
 Posted: Thu Jan 26, 2012 1:04 pm |
I would also like to know how you can tell if a CV is stuffed/broken, and what the symptoms would be... and it would be nice if someone can give an answer this time...
DarkHorse
 Posted: Thu Jan 26, 2012 1:18 pm |
For me it was pretty easy - lock hubs, engage 4WD, point uphill, spin back wheel. If front wheel no spin, CV shagged.
MacDaddy
Vehicle: Jeep
 Posted: Thu Jan 26, 2012 1:26 pm |
DarkHorse wrote: For me it was pretty easy - lock hubs, engage 4WD, point uphill, spin back wheel. If front wheel no spin, CV shagged.
Ok thanks, but i would like to find out before i go offroad, is there any way to tell without putting it in 4WD ?
christover1
 Posted: Thu Jan 26, 2012 8:31 pm |
When cv is broken, you can rattle the axle around very easily with your hand.
There is never any doubt when they busted.
Clicking, or close to busting can only really be tested driving.
just_cruizin
Joined: Sun Jun 25, 2006 11:30 pm Posts: 2867 Location: here
 Posted: Thu Jan 26, 2012 8:36 pm |
jack up the front end, lock the hubs and rotate the wheels by hand, if it feels like you mixing a can of rocks with a fork it's stuffed.
_________________ greenzook89 wrote: 31zook wrote: Makes me want something similar
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9716 Location: NSW
 Posted: Thu Jan 26, 2012 9:35 pm |
bailey08 wrote: I have an AWN warranty which is great(they've replaced the ECU after jump starting and a starter motor, no questions asked at no cost to me).
Its a catch 22.
I have had this on my Subaru, I blew a boot, Grease went everywhere, AWN dont warranty cv boots!, But they also dont warrant a part that have been run it to ground because of something else happened. Eg: gearbox oil leaked out, then driven for 100ks. car wont go anymore. Its a crock of shit.
I ended up filling the cv with grease, and putting a new boot on. Still ok. If it was clicking, then i would go to AWN and say its rooted.
I have a engine light and my cruise flashing at me now in my outback, have to find the warranty sheet, and ring them. HOPEFULLY they cover this!
atari4x4
 Posted: Thu Jan 26, 2012 9:37 pm |
MacDaddy wrote: I would also like to know how you can tell if a CV is stuffed/broken, and what the symptoms would be... and it would be nice if someone can give an answer this time...  which bit of this didn't you understand?  atari4x4 wrote: If the CV clicks it's stuffed
if it's clicking it's well on it's way to being rooted, being a GV & most likely still ruuning the original set up, the CV's are constantly spinning slowly wearing a groove in the straight ahead position & when you put it in 4wd & turn the wheel the CV will click as it rides over the worn groove.... you know the click clack click clack noise you often hear when a Magna/Carmy pulls into a carpark, that is the sound of a stuffed CV.
a rooted CV will make a hell of a racket & there will be no drive to that wheel.
buzbox
Joined: Thu Jul 16, 2009 11:30 pm Posts: 3600 Location: Wollongong NSW
Vehicle: LWB Sierra & XL7
 Posted: Thu Jan 26, 2012 10:06 pm |
atari4x4 wrote: CV's are constantly spinning
Wow, that's why they're called Constant Velocity shafts...
Joined: Sat Aug 12, 2006 11:30 pm Posts: 6456 Location: Radelaide ofcourse!
 Posted: Thu Jan 26, 2012 10:08 pm |
In a 4wd they're part time velocity joints
_________________ Chop
atari4x4
 Posted: Thu Jan 26, 2012 10:12 pm |
buzbox wrote: atari4x4 wrote: CV's are constantly spinning Wow, that's why they're called Constant Velocity shafts...
no shit Sherlock...
you do realise the GV's don't run free wheeling hubs? so when they would be stationary when in 2wd in a Vitara, in a GV they are constantly spinning when in 2wd, creating more wear on the joints & boots.
bailey08
Vehicle: 02 GV
 Posted: Fri Jan 27, 2012 1:28 am |
I put manual hubs on aver a year ago in the hope of getting better fuel economy. I only engage them when off road. No noticable change in fuel usage though.
steve
Joined: Sun Jun 11, 2006 11:30 pm Posts: 7681 Location: Brisbane
Vehicle: 75 Cruiser
 Posted: Fri Jan 27, 2012 1:34 am |
You can only tell when it's obviously stuffed. Sometimes they're stuffed/cracked and still work.
You can put the car up on one wheel and jiggle your balls around and do a rain dance and think that the CVs are still good, but they can still be cracked.
So you can never really tell unless you pull them out and look. (the CVs that is)
BlueSuzy
 Posted: Fri Jan 27, 2012 1:37 am |
steve wrote: So you can never really tell unless you pull them out and look. (the CVs that is)
Do this
just_cruizin
 Posted: Fri Jan 27, 2012 3:14 am |
and in which case you might as well fit a new one.
If it's clicky it's stuffed. In FWD vehicles you always replace them if they click.
MacDaddy
Vehicle: Jeep
 Posted: Fri Jan 27, 2012 4:23 am |
atari4x4 wrote: MacDaddy wrote: I would also like to know how you can tell if a CV is stuffed/broken, and what the symptoms would be... and it would be nice if someone can give an answer this time...  which bit of this didn't you understand?  atari4x4 wrote: If the CV clicks it's stuffed if it's clicking it's well on it's way to being rooted, being a GV & most likely still ruuning the original set up, the CV's are constantly spinning slowly wearing a groove in the straight ahead position & when you put it in 4wd & turn the wheel the CV will click as it rides over the worn groove.... you know the click clack click clack noise you often hear when a Magna/Carmy pulls into a carpark, that is the sound of a stuffed CV. a rooted CV will make a hell of a racket & there will be no drive to that wheel. Yes clicking, ok... so it only clicks in 4WD ? I have Hubs fitted... both me and monkey heard a sharp bang last trip, from the front passenger wheel, we both thought it was a CV, but i kept driving it in 4WD and heard nothing, and it kept driving in 4x4 ok... could it still be a CV, just not clicking ? Or could it be something else ? Any idea's ? I am trying to get some simple, but important, info out there, not only for myself, but for others who are reading this, who dont know much ! Remember Royce saying he would like to see more Tech with proper correct info, no dribble...  steve wrote: You can only tell when it's obviously stuffed. Sometimes they're stuffed/cracked and still work.
Ahhh ok... this is good to know !
Damn, ok, will have to get it checked next service, or sooner if it goes completely...
bailey08
Vehicle: 02 GV
 Posted: Mon Feb 27, 2012 5:41 pm |
So I now have new CV's with no out of pocket expence.
Question though, I now have shinny new bits that go into the wheels and boots but the shafts and bits that go into the diff are the same. what have they changed/replaced.
atari4x4
 Posted: Mon Feb 27, 2012 5:45 pm |
sounds like they've just changed the outer CV's... pics would be helpful
bailey08
Vehicle: 02 GV
 Posted: Mon Feb 27, 2012 6:06 pm |
Had a look today and yes they only replaced the outer cv and boots (I got the old cv's). He said AWN would only replace the outer cv, atlest if the inner cv goes I know they'll replace it and I still have at least 2 and a half hears left on my warranty.
