It is currently Tue Aug 04, 2026 9:46 am
Post new topic Reply to topic  [ 76 posts ]  Go to page Previous  1, 2, 3
Post Posted: Wed Jan 25, 2012 10:16 pm
sogone wrote:
TAC board for the win!
Hopefully
Post Posted: Tue Jan 31, 2012 6:31 am
any reason why i shouldn't just chop the rear suspension out of my parts vit and then glue it into my sierra?
Post Posted: Tue Jan 31, 2012 7:42 am
Other than the way the a frame meets the diff, I had the same idea.
Vehicle: 75 Cruiser
Post Posted: Tue Jan 31, 2012 7:43 am
the links might be a bit short?
Post Posted: Tue Jan 31, 2012 8:01 am
The a arm bolting to the diff center is a pita
It flexes well but it would need a sway bar
The arms are short so u get heaps of rear steer when flexed
Post Posted: Tue Jan 31, 2012 9:48 am
There is nO engineer to get involved. We do a submission to a commitee made up of car enthusiasts and they decide what the next steP is. If they like it then ya get the go ahead.
Welding on the chassIs is unavoidable however if I can use factory suspension bits then it will look a lot better on paper.
Don't stress on the welding part.
Under NT rules any chassis welding only needs to be done by someone with the relevant AS certification. There are enough of them around here to be easy enough to do.
Post Posted: Tue Jan 31, 2012 9:55 am
Sounds wise to me, but I no engineer.
You could include part of the vit chassis, too, if that helped
Post Posted: Mon Apr 23, 2012 9:04 pm
I'd argue the flex's well part, if you are after some good flex the A arm ball joint to your diff will be your weak point.
But you could change it up with a massive hectic rose joint.
Shep's let me know how you are going, I just discovered a 100 Series cruiser down the tip and I'm gonna flip the chassis on Wednesday and take all the bits off it. Including the OME suspension and the front ARB Bull bar. Armsup
Post Posted: Mon Apr 23, 2012 10:11 pm
Damn you guys have good dumps
Post Posted: Mon Apr 23, 2012 10:15 pm
8O that's a bit personal
sure do...
Oh wait ... you meant like rubbish dump... :?
Post Posted: Mon Apr 23, 2012 10:30 pm
All good shit
Post Posted: Wed Apr 25, 2012 1:00 pm
So went down to the dump, realised I don't have sockets big enough to take any of the control arms off out here with me. Anyway I walked around for a bit and found a pallet with front control arms just sitting on them so I took them instead.. so so much easier.. Armsup
I was thinkin, whilst totally over kill a single front control arm could work as a rear anti wrap bar on a Sierra with SPOA..?
Post Posted: Wed Apr 25, 2012 1:29 pm
You could but it will need a shackle on one end for the push pull movement, like a slip joint on your driveshafts
Post Posted: Wed Apr 25, 2012 1:41 pm
I was thinking this last night. I might give my mate $20 for his patrol radius arm..
Post Posted: Wed Apr 25, 2012 7:04 pm
Yep, it's definitely been done. Don't skimp on the bracketry on the diff end. Traction bars exert a LOT of force on the axle housing.
Users browsing this forum: BZOOK, Google [Bot] and 275 guests
