It is currently Tue Oct 20, 2026 2:14 am
Post Posted: Thu Feb 02, 2012 7:31 am
Gday
During my daily ponderings on the internuts i stumbled across these on ebay. anyone tried them before?
http://www.ebay.com.au/sch/i.html?_nkw= ... m270.l1313
Dunno if they'd hit the ground on those hard fourby sessions but look like a good idea otherwise.
MY BUILD THREAD HERE!!!!!
Post Posted: Thu Feb 02, 2012 9:42 am
They shouldn't - given the fact that the front axle is below the sump - but I wouldn't use them.
Consider the following ...
1) How thick is the sump where the drain plug goes in?
2) How long is the threaded portion of the fitting?
3) How high above the floor of the sump will the end of the fitting be?
And finally - what's on the floor of the sump? My guess is that's where the sludge and muck you want out of the sump will be, and once that fitting projects above the floor of the sump, when you drain the oil, you're trapping that muck in there.
Post Posted: Thu Feb 02, 2012 10:02 am
On your Jimny, How close does your tierod come to the sump?
Post Posted: Thu Feb 02, 2012 10:09 am
dunno blue,
at work till wednesday so cant look.
@fordem
valid points, would have to look at the item closer to know of course.
Vehicle: Suzuki Grand Vitara
Post Posted: Thu Feb 02, 2012 4:40 pm
I have one on my Vitara, but not that design, I don't like how you could just open the valve so easy.
This is the brand I have and it sits flush with the pan. Therefore, all of the oil is drained.
http://www.nospillsystems.com/home
viewtopic.php?f=5&t=28972
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 243 guests
