It is currently Thu Nov 05, 2026 4:19 am
Post Posted: Thu Feb 02, 2012 9:15 pm
Does anybody know a good place that could press a new bearing onto my rear sierra axle? Any recomendations would be appreciated.
Post Posted: Fri Feb 03, 2012 11:12 am
I thought hammers were invented so you didn't need a press :P
 Profile WWW ICQ YIM
Post Posted: Fri Feb 03, 2012 11:56 am
I don't know where abouts you are but I take all the stuff I need a press for to Tyres and More in Port Kennedy, they are always happy to help out and on ask for a few bucks. I had them press out the old bushes in my tailing arms and clean them up for 20 bucks. Hope that helps if not use your jack to create a press but ensure you employ safety squint and stand back.......ha ha.
DUXY
Post Posted: Fri Feb 03, 2012 12:45 pm
I got a 20 ton press here mate I'll do it for ya if you can get to Rockingham
Post Posted: Sat Feb 04, 2012 10:54 pm
Cheers guys, got it done in midland, cost me 40bucks! 8O which was actually the cheapest quote I got, had to be done Friday though.
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Mon Feb 06, 2012 11:54 am
Heads up for next time, a length of pipe on top of the old bearing presses in the shrink ring in a few taps, is cheaper than $40 and re-usable.
I got it from bunnings as it was a Sunday.
Post Posted: Mon Feb 06, 2012 12:51 pm
When re-installing the shaft into the rear housing, how much of the bearing should be protruding from the housing (if any)? I have about 2mm of bearing exposed outside the housing, I presume the recess in the brake drum is to allow for this? Cheers guys.
Post Posted: Mon Feb 06, 2012 1:37 pm
Just jam it in as best you can, tighten the bolts then wheel already!
 Profile WWW ICQ YIM
Users browsing this forum: No registered users and 543 guests
