It is currently Thu Oct 29, 2026 10:46 am
Post Posted: Sat Feb 04, 2012 8:50 am
Gday all
Just wondering if this is a standard issue, when i turn the wheel left the handbrake light comes on, turn right, nothing happens!!
About to go crawl under the car but i thought id ask here too
It has a slight lift, but prob total of about 1.5" rims are stock and tyres are 215/75s
Cheers!
Post Posted: Sat Feb 04, 2012 8:57 am
Check ya brake fluid level. Can also be the sensor for the fluid indicator.
Post Posted: Sat Feb 04, 2012 9:06 am
cheers thanks!!
Vehicle: 4wd
Post Posted: Sat Feb 04, 2012 9:08 am
As sogone said, check the fluid level.
The hand brake switch is inside the cab on the back of the handbrake lever. The cable runs under one of the seats.
Watch out or you'll get sued.
Post Posted: Sat Feb 04, 2012 9:17 am
thanks guys brake fluid is sitting just at min level
Will grab some today and top her up
Post Posted: Sat Feb 04, 2012 9:20 am
Check your blinker fluid while your at it!
Vehicle: 4wd
Post Posted: Sat Feb 04, 2012 10:36 am
And ya rear wheel cylinders!
Post Posted: Sat Feb 04, 2012 12:17 pm
You guys are terrible.
Post Posted: Sat Feb 04, 2012 12:39 pm
thanks again all!
and yes terrible..... but humorous at the same time
Vehicle: 4wd
Post Posted: Sat Feb 04, 2012 1:23 pm
lukemc wrote:
thanks again all!
I was serious. Check your brake cylinders, it's likely you are loosing fluid there.
Users browsing this forum: Google [Bot] and 337 guests
