It is currently Thu Oct 29, 2026 11:10 am
Post Posted: Thu Feb 09, 2012 11:45 pm
Got sick of having no interior light, so I went to the wreckers and found this
Made a spacer for it out of some MDF
Had to change the wiring in the back of it to suit the negative switching, just a matter of connecting the two power wires together, and separating the two earth's (one switched, one not) the light already had separate earth's for the main light and the map lights.
The main light now only operates on the door's, you cant turn it on with the 'on' switch, the 'on' switch is actually the 'door' function.
Also planning to run a switch to the rear near the tailgate, so I can turn it on from the back of the car. (i could also add a switch next to the light to restore the 'on' function
The map lights have constant power ( i should probably run a separate wire to them on 'acc' so they don't get left on.
I may even get tricky and try and fix the switching of the 'on' button on the light at the same time.)
The light is out of a galant, and is a very good fit for the 'roll bar thing'
Post Posted: Sat Feb 11, 2012 7:36 pm
Pulled it apart again today, seems the light was already set up for negative switching... doh...
So I added a relay to give me a switchable earth on accessories, and ran another wire up to it... it now works fully as intended, with the main light 'on' function and the map lights coming on with the key, and the 'door' function always operational.
I also spliced a wire into the original door switch (earth) wire, and put a switch near the tailgate, so i can turn the light on from the back of the car, when i get shopping/go camping ect.
Post Posted: Sun Mar 11, 2012 10:58 pm
Sweet, the stock light always kinda sucked lol. I dig this one.
Post Posted: Mon Mar 12, 2012 2:38 am
I was wondering about that - every car I've ever worked on had negative switching on the dome light - makes for a lot less wiring with the multiple switches required.
Users browsing this forum: No registered users and 9 guests
