It is currently Wed Nov 04, 2026 12:39 am
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2  Next
Post Posted: Sun Feb 12, 2012 9:05 am
really cant be fucked trauling the forum through old topics for this.
but has anyone replaced the body mounts and had luck with this stupid lean ?
or even just proped the body up slightly on one side so its not noticable ?
and lastly, is it just mine. or does everyones leans vary depending on the day ? .... some days it looks fine, others its leaning like hell !
thanks
Post Posted: Sun Feb 12, 2012 9:16 am
really can't be fucked typing a reply to this... but if you did troll through the old topics you'll find that it's not a body mount problem & spacing the body mount is a bit of a band aid solution.
Post Posted: Sun Feb 12, 2012 9:20 am
X 2 .... :wink:
Post Posted: Sun Feb 12, 2012 10:16 am
So you can't be fucked doing a search so you want us to type a special response just for you.
Sorry, you aren't special enough.
Post Posted: Sun Feb 12, 2012 11:20 am
Armsup mate, your not really gunna get any form of help with statements like that, those that answered are in the above average class of suzi people who help all the time.
I hate to say it, but a bit of a quick search will tell you heaps on suzi lean, its as common as dogs balls, your research will also tell you how others have dealt with it, and overcome it.
Post Posted: Sun Feb 12, 2012 11:41 am
:roll: :roll: :roll: :roll: sorry had the answer, but couldn't be fucked typing it in the end :!: :!: :!:
Vehicle: 2002 GV V6 and self shifter
Post Posted: Sun Feb 12, 2012 5:43 pm
Just thought I'd pint out that the lean isn't just isolated to suzukis
My daihatsu used to do it
Early (and late) land rovers do it
If the car has one person in it most of the time then it will most likely lean that way
Some quick ideas on how to fix it
*Sit on the other side of the car when you drive
*Get a fat arse rotund girlfriend to go with you everywhere - the lean might happen on the other side then
*Swap springs form side to side (this will fix it for a short while
*Get springs that are a slightly higher rate for the side that leans compared to the side that doesn't
*Get airbags for the back and pump up the leany side more than the non leany side
There is probably more ideas out there. BTW it took me longer to make this shit up than search for the real answers
Post Posted: Sun Feb 12, 2012 5:45 pm
try fitting 32's on the RHS & 31's on the LHS
Vehicle: Ducati Monster
Post Posted: Sun Feb 12, 2012 5:48 pm
swap the discombobulator from behind the rear diff on the RHS to the LHS on the front diff just in front
Post Posted: Sun Feb 12, 2012 5:51 pm
I heard if you take the bottom all of the bottom leaves out of the packs on the high side, it evens it out. I was going to do this, but i couldnt be bothered.
Post Posted: Sun Feb 12, 2012 6:10 pm
Farken genius!!! Tho that costs money! Just increase the pressure on the low side to 40psi and drop the high side to 2! Done and dusted!
Lil Foot!
Post Posted: Sun Feb 12, 2012 6:53 pm
Run a ratchety strap around the diff up to the chassis, do it up until the car is level. problem solverd
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
Post Posted: Sun Feb 12, 2012 7:01 pm
buy a hilux and annoy them with un researched problems.
Vehicle: '91 Sierra, Fluffy Dice.
Post Posted: Sun Feb 12, 2012 10:19 pm
Put a 2inch lift on one side and leave it stock on the other, or a better idea is body lift one side so it looks like its level
If at first you don't succeed, get a bigger hammer
Post Posted: Sun Feb 12, 2012 11:02 pm
ride a bike
Vehicle: '94 suzuki maruti
Post Posted: Sun Feb 12, 2012 11:45 pm
dont forget, you need to leave your lockers engaged when you do this. :roll:
Vehicle: 96 sj70+80 tintop sierra
Post Posted: Mon Feb 13, 2012 5:29 am
I had someone tell me to shave my body lift to fix lean problems. I wanted to slap them but remembered they only ever had patrols so just walked away so I didn't hear all the dodgy shit done to theirs..
Post Posted: Mon Feb 13, 2012 6:44 am
30 sec and its amazing what you can find.
search.php?keywords=sierra+lean&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
But this is prob the best
viewtopic.php?f=5&t=28729&hilit=sierra+lean
Post Posted: Mon Feb 13, 2012 8:03 am
Or...............
Get the fuck over it would be a better option
Post Posted: Mon Feb 13, 2012 3:08 pm
zooks are supposed to lean. any regular 4by can sit level,
a leaning zook is sticking it up the shiny bling busses and telling them "bin there done that, get outta my way cause I'm ready for more"
stephen
Post Posted: Mon Feb 13, 2012 3:30 pm
make up longer shackles for the RHS
Post Posted: Mon Feb 13, 2012 4:27 pm
Just found a new market assymetrical body lifts
Post Posted: Mon Feb 13, 2012 4:31 pm
can you make them adjustable as the OP states that some days it leans more than others? surely a man of your calibre could be able to accommodate such a request. :D
Vehicle: On the lookout
Post Posted: Mon Feb 13, 2012 5:47 pm
Fit adjustable panhards
Crispy old grand vitara
Post Posted: Mon Feb 13, 2012 5:50 pm
How will that help? :?
Post Posted: Mon Feb 13, 2012 5:55 pm
Hydraulic bodylift 8)
Made in JP. Built in WA.
Post Posted: Mon Feb 13, 2012 6:00 pm
Dont they come with the door handle lowering kit? :wink:
Post Posted: Mon Feb 13, 2012 6:01 pm
what about doing a SPOA on the RHS only.
Got the answer but could be fucked typing it out. Go search :mrgreen:
Post Posted: Mon Feb 13, 2012 6:07 pm
Can't. Spilled snake oil in my keyboard :cry:
Users browsing this forum: Google [Bot] and 94 guests
