It is currently Wed Jul 22, 2026 6:30 am
Vehicle: 75 Cruiser
Post Posted: Sun Aug 03, 2008 11:51 pm
Thought i'd stick this in here...
I made some control arms using the "pin" end of my old ones and the bush end of some standard control arms.
The small tube is 32mm round, and the bigger tube is 32nb, so the bigger tube slides over the smaller tube.
I ground the ends down with a V shape in between the end and the tube and then ran a weld filling in the V shape.
I did the same with the other bush end.
Then cleaned up the weld to make it flat so i could slide the bigger tube over the outside.
The bigger outside tube is longer than the smaller tube so it covers the other welds and i welded the bigger tube at the ends. Before i put the big tube over the small tube i drilled some holes along the sides and then weled them up once the tube was on.
Post Posted: Mon Aug 04, 2008 1:41 am
Looking good Steve 8)
Was that this weekends effort?
Vehicle: 75 Cruiser
Post Posted: Mon Aug 04, 2008 10:35 am
that was from a couple weekends ago, i didn't do anything on the car this weekend :oops:
Post Posted: Sat Aug 16, 2008 12:02 pm
What are you doing up front now that you've chopped up your trailing arms?
Post Posted: Wed Feb 25, 2009 2:21 pm
ey mate i was looking to do somthing similar...how is drivibility,and travil?with just one mounting point to the diff??
Post Posted: Wed Feb 25, 2009 2:26 pm
It does a top speed of about 20kmh :lol:
Post Posted: Thu Feb 26, 2009 11:24 am
if you look closley it has 2 upper arms locating the diff as well
Users browsing this forum: No registered users and 22 guests
