It is currently Sun Jul 26, 2026 12:02 pm
Post new topic Reply to topic  [ 251 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9  Next
Post Posted: Thu Jan 12, 2012 9:43 pm
Thats a really bad fit.
The better ones are when the pipes are offset to each other.
So even if you hammer them, looks like the left pipe might be half crushed for clearance, then how close is they other to the chassis??
What make and number are they?
Post Posted: Thu Jan 12, 2012 11:33 pm
There's ones are Jimny Hurricane extractors
This is the other side
Post Posted: Fri Jan 13, 2012 1:08 am
Are you able to take them back? Say they don't fit right on your jimny, ask for a different brand.
Post Posted: Fri Jan 13, 2012 1:58 am
I just used a grinder to take the corner of the chassis mount off. Not running a body lift. Mine are extractors of unknown origin, maybe PJ.zook will see this and comment on what they are. Pete ran a 1 inch body lift I think and they cleared well.
Post Posted: Fri Jan 13, 2012 2:02 am
we had a similar issue, just setup in a press and flattened them slightly.
Post Posted: Fri Jan 13, 2012 3:54 am
Yeh mite give them a call see if they have another brand first. Not that keen to hite it with a hammer just ATM
Vehicle: 2018 DMAX
Post Posted: Sun Feb 05, 2012 8:05 pm
So going by the posts at the start of this thread, to run the Baleno dizzy motor I need a Vitara cam and right angle drive? I assume the Baleno harness and ecu are fine with this combination.
Is this the only option other than cutting the firewall up?
Post Posted: Mon Feb 06, 2012 5:06 pm
Dont cut the firewall mate. it will never pass for a mod plate. also the baleno dizzy sticks out heaps so it would be well and truly in the firewall. i bought a running 95 baleno to do a swap a while ago.
but it is to good on fuel and couldnt be bothered to do the cam and dizzy crap so i looked around some more and i found one =)
so look around if you havnt already found a motor. there could be a nice coil pack g16b just around the corner. i just found one for $350 including ECU and harness.
so im just about to get my conversion build up and running. =)
Vehicle: Sold zuk got a Bt50
Post Posted: Wed Feb 15, 2012 5:03 pm
CairnsZook wrote:
Here's my "lengthened" Baleno fuel pump.
The return line is still a little short. I can't see it being a problem though, as the fuel will be returned to the swirl pot anyway.
Where abouts did you get your pump from and how much did it set you back and also with fuel lines where did you get the EFI lines from ??
bt50 now but still love the zooks
Vehicle: Zookless
Post Posted: Fri Feb 17, 2012 8:32 am
Fuel pump and flange came out of a 2000 Baleno at a wreckers in Hobart. No idea how much it cost, it was a while ago now.
Tip: snip off the pink and black wires and take the plug too.
Fuel lines were purchased at Supercheap. You don't need many, as you can use your existing steel lines.
Post Posted: Sat Mar 17, 2012 6:23 pm
Just wondering if the vl engine mounts would be suitable for a g16a 8v in a sierra. Have you got the part numbers for them.
Post Posted: Sun Mar 25, 2012 7:37 pm
YEp they will fit. They will make the motor sit abit taller. make sure you have clearance to the bonnet.
Vl mounts with the 6cyl rb30 motor.
Post Posted: Sun Dec 09, 2012 3:27 pm
Here is the ben t install instructions
Im doing this atm and this looks like the best place to add this.
 Profile YIM
Post Posted: Wed Dec 12, 2012 8:57 pm
http://suzukibaleno.narod.ru/diagrams.html
 Profile YIM
Vehicle: Daisy
Post Posted: Sat Dec 29, 2012 4:07 pm
Jimbo that link looks like it will be super helpful!
Post Posted: Wed Jan 23, 2013 6:31 pm
can I use the vitara engine fan on the baleno water pump?
 Profile YIM
Vehicle: Suzuki sierra
Post Posted: Thu Jan 24, 2013 4:51 am
CairnsZook wrote:
Thanks Steaks, I ordered one from there this arvo.
Also got new clutch cable, gearbox bushes, and gearbox plugs (cos I had to chisel one out :roll: )
Those mounts look good Phil, I'll get some of them too :)
Here's my very flash machined flywheel:
And my pink HD clutch:
All bolted together :D
What gear box is that ?
Post Posted: Thu Jan 24, 2013 7:25 am
Sierra 1.3
Steve
Vehicle: 92 tintop sierra
Post Posted: Thu Jan 24, 2013 8:43 pm
Looks chunkier than my 1.3 box :S
Vehicle: '94 Sj413, 1.6 baleno convert
Post Posted: Thu Jan 31, 2013 5:00 pm
Good info in here, CairnsZook, is your zook body lifted?
Does the lift affect the fitment of those Hurricane extractors?
I ask because mine isn't lifted and I will be fitting the same engine.
Vehicle: Zookless
Post Posted: Mon Feb 11, 2013 12:20 pm
Yep, 25mm body lift.
Lift does not affect extractor clearance. My extractors do just touch the gearbox though. (Like Ratty's pic on the previous page).
Post Posted: Mon Feb 11, 2013 12:55 pm
Cheers mate!
Post Posted: Tue Mar 12, 2013 11:15 am
EDIT - should have read the thread again... found my answer!
Post Posted: Fri Apr 05, 2013 6:37 pm
Just adding to Cairnszook's great baleno conversion thread. This is what I have done with the coolant hoses intead of making a hard line which runs over the headers which some people do. As Cairnszook has done I used the early model swift thermostat housing -> baleno top hose -> 28mm temp sensor adaptor -> ford laser top hose -> factory sierra radiator. It seems to all fit really well and clears everything. I'm running the factory sierra temp sensor in the adaptor so I don't have to mess with the factory temp guage. The other hoses are factory sierra bottom hoses to the factory sierra coolant pipe on the back of the water pump.
part numbers: MACKAY radiator hoses from supercheap auto.
baleno hose - CH2068
laser hose - CH2261
28mm adaptor - $15 from ebay
Vehicle: 4wd
Post Posted: Sat Apr 06, 2013 6:53 am
laser hose - CH2261
That works really well, one of the neater ways around the problem.
Don't forget to mod and put the intake manifold brace back on.
Watch out or you'll get sued.
Post Posted: Sun Apr 07, 2013 4:46 pm
I nearly forgot about that manifold brace, I removed it when putting the sierra engine mounts on because it wouldn't fit. I guess I'll have to modify it to make it fit?
Vehicle: Soon to be Sierra (hopefully)
Post Posted: Fri Nov 08, 2013 4:47 pm
so the E-W configuration on the baleno can go N-S ?
i got a 2000 model baleno 100k on the clock with a 5 spd (full car) ill be ripping stuff out of. This is the configuration (not the same car obviously) Image.
what should i scavenge from it, before i roll it down the hill
Post Posted: Fri Nov 08, 2013 4:50 pm
edit - yes its a coiley tank lol
Vehicle: 89 Sierra Widetrack
Post Posted: Fri Nov 08, 2013 5:08 pm
Hi Mate
Engine, loom, cluster
Post Posted: Mon Nov 11, 2013 10:19 pm
Ate the two heater hoses that go into the baleno heater box usable on the sierra or should I just cut them off?
Users browsing this forum: No registered users and 52 guests
