It is currently Thu Oct 01, 2026 11:55 pm
Post Posted: Sun Mar 01, 2009 2:39 pm
just wondering if the centres are the same front and rear coz i want to put my lockrite in the front
Vehicle: MY2019 Jimny
Post Posted: Sun Mar 01, 2009 3:03 pm
I think if it is the lock right with the couplers, then you cannot.
Otherwise you may be able to - Is your truck a WT or NT? I have a feeling only NT ones fit LRs in the front...
Post Posted: Sun Mar 01, 2009 3:11 pm
i have a lockright in the front diff of my W/T, still 2 pin carrier.
Post Posted: Sun Mar 01, 2009 3:14 pm
I am thinking of moving my LR to the front diff, as 90% of my driving is on road... Probably going to 3.9 ratio as well, 5.12 is way slow.
Post Posted: Sun Mar 01, 2009 3:24 pm
the only way it will work in your front diff is with rear axle splines
i think the H/D front axles and cv have the 26 spline axles.
you need the lockright without carrier to fit in a stock front.
let me know if you wanna hock your diff gears off i know a fella that is chasing
some and there are no diff bits in the NT. i cant even find a set of 3.9s
and MUD-PIG has had no luck on finding a 3.7 center.
Post Posted: Sun Mar 01, 2009 3:29 pm
So use the front carrier, with the lockright and 26 spline axles?
I need the 26 spline axles because of the couplers, correct?
Post Posted: Sun Mar 01, 2009 6:32 pm
yep. the coupler replaces the side gears which drive the axle.
Post Posted: Sun Mar 01, 2009 6:47 pm
Are the front carriers 4 or 2 pin generally?
Post Posted: Sun Mar 01, 2009 6:53 pm
mostly 2 pin for a WT some sj50 WT have a 4 pin but mine didn't.
Post Posted: Sun Mar 01, 2009 7:43 pm
buy these
http://www.trailtough.com/index.php?pag ... &Itemid=53
and then you can run your rear locker
Post Posted: Sun Mar 01, 2009 9:01 pm
Will the whole rear centre fit?
Shep, do you have Messenger?
Post Posted: Sun Mar 01, 2009 9:10 pm
i dont know what you are talking about so i suppose no i don't :lol:
Post Posted: Sun Mar 01, 2009 9:14 pm
Windows live messenger - it is like talking, but with typing instead of moving lips. It would enable me, or others to chat to you, which would be good as you are some sort of suzuki oracle...
Oh and answer my previous question fukya...
Vehicle: WR250F/Jeep XJ
Post Posted: Sun Mar 01, 2009 10:55 pm
From my experiences, Pre mid 1988 WTs and 1.3 NTs had 4 pinion front diffs. I have an april '88 build WT sierra and it had a 4 pinion front. Third members are interchangable from front to rear. just need to swap the spider gears in the centre unless you have HD 26 spline axles.
When I got my airlocker, I pulled the axles and the removed the whole 3rd member centre with lockrite installed and just bolted it into the rear. My airlocker then was installed into my rear diff and shoved into the front housing with the hd axles. works good mate!
Post Posted: Sun Mar 01, 2009 11:21 pm
Shep from NT must be new to the internets..
Like Kurrajong Heights 8O
Post Posted: Mon Mar 02, 2009 12:55 am
i am no oracle mate i just have a lot of spare time for research and diffs are something that i have put together for a few people in Darwin and Katherine.
ball actually does the measuring tech stuff though.
a rear diff center will bolt into the front diff all that needs to be changed is
the side gears as the front and rear axles have different splines.
N/T centers will bolt into W/T diffs but the tail shaft flanges are different,
what we did on a mates car was to make a W/T-N/T hybrid tail shaft.
haha yep i have just discovered the internet and this took 20min to type,
but fuckyas i live in the real bush. :finger:
Post Posted: Mon Mar 02, 2009 1:03 am
Cool, thanks all... now I have some understands.
Post Posted: Mon Mar 02, 2009 1:36 am
He only got a mobile phone 2 or 3 years ago. He is a few years behind 8O
Post Posted: Mon Mar 02, 2009 1:43 am
get ya facts strait mate 14 months now. :lol: best recovery device invented.
Post Posted: Mon Mar 02, 2009 6:26 am
at the moment i have a rear airlocker but i have sourced some spoa axles which have mechanical lockers front and rear. i have been told to put the air from the rear in the front and run a rear mechanical can this be done? also what do i need to change? the new diffs have centre reduction
Post Posted: Mon Mar 02, 2009 1:02 pm
What ratios are the new diffs?
Post Posted: Mon Mar 02, 2009 4:14 pm
Let me know when you want to sell the 5.12's. I have a set of 3.7's if you can't find 3.9's.
Post Posted: Mon Mar 02, 2009 4:46 pm
I am not sure how will I be able to tell
Post Posted: Tue Mar 03, 2009 2:06 am
WT = 3.7. NT = 3.9. Providing no-one has swapped the ratios.
And to add some more tech
WT maruti's have 4-pin front diff Armsup
Member of C.O.R 4x4
Post Posted: Tue Mar 03, 2009 2:38 am
3.7 ring gear has 41 teeth 3.9 has 43
Users browsing this forum: No registered users and 193 guests
