It is currently Fri Nov 13, 2026 8:53 am
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
Poll: Is this useful info and should this be made sticky?
Yes 84%  84%  [ 58 ]
No 16%  16%  [ 11 ]
Total votes : 69
Post Posted: Mon Nov 02, 2009 2:18 pm
I am after some information and I am sure with some of the people that are here this will be easy.
Brake to brake widths for different axles. This info will be great for anyone doing an axle conversion or an SAS.
We should start with the easy ones (Suzukis') and then add compatible axles as we find them.
The List
LJ50
Front 1130mm
Rear 1140mm
LJ80
Front 1230mm
Rear 1240mm
Sierra NT
Front 1250mm
Rear 1260mm
Sierra WT
Front 1340mm
Rear 1350mm
Vitara
Front 1435mm
Rear 1440mm
Vitara V6
Front
Rear
Jimny
Front
Rear
Grand Vitara
Front
Rear
Grand Vitara XL7
Front
Rear 1510mm 8O
Donors
Hilux (79-85)
Front 1397mm
Rear 1397mm
Hilux (86- )
Front 1397mm
Rear 1473mm
Bundera (insert year)
Front 1397mm
Rear
TJ Wrangler (Danas')
Front Dana 30 1563mm
Rear Dana 44 1563mm
Cruiser (40 Series)
Front 1447mm
Rear 1397mm
Cruiser (60 Series)
Front 1524mm
Rear 1473mm
Cruiser (70 Series)
Front
Rear
Cruiser (80 Series)
Front 1625mm
Rear 1612mm
Patrol MQ
Front 1422mm
Rear 1422mm
Patrol GQ
Front 1574mm
Rear 1574mm
Post Posted: Mon Nov 02, 2009 2:27 pm
Hilux ifs rear
Cruiser 70/3/5/8/9 series.
Cruiser 100 series. Solid axle front.
Pootrol Mq/Mk
Pootrol GQ
Pootrol Gu
Good idea but no need to make a poll about it. :lol:
Post Posted: Mon Nov 02, 2009 2:33 pm
Never did a poll before :lol: probably wont do one again :wink:
Post Posted: Mon Nov 02, 2009 2:40 pm
oh :? :lol:
Vehicle: MY2019 Jimny
Post Posted: Mon Nov 02, 2009 8:25 pm
Timmay has done plenty of poles...
Post Posted: Mon Nov 02, 2009 10:01 pm
timmy got his freak on :lol:
Post Posted: Tue Nov 03, 2009 12:25 pm
I dont think i have done any polls.
But when you tell your missus about the suzuki, she wont be climbing your pole anytime soon.( i so hope she reads this) :P
Post Posted: Tue Nov 03, 2009 2:44 pm
By brake to brake width do you mean WMS to WMS?
Not trying to be a picky bastard, just other resources (pirate, IH8MUD) use WMS.
cheers, Davo.
Vehicle: I drive your mum
Post Posted: Tue Nov 03, 2009 10:11 pm
cheers, Davo.
Wheel mounting surface - as in the flange that that the wheel mounts against. Diff measurement is done from one WMS to the other WMS.
Layto....
Post Posted: Tue Nov 03, 2009 10:18 pm
The List
LJ50
Front
Rear
LJ80
Front
Rear
Sierra NT
Front - 50
Rear - 50
Sierra WT
Front - 52
Rear - 52
Vitara
Front ?
Rear - ~56
Vitara V6
Front
Rear
Jimny
Front
Rear
Grand Vitara
Front
Rear
Grand Vitara (Independent)
Front
Rear
Donors
Hilux (insert year)
Front - 55 (Pre IFS)
Rear - 55 (pre IFS) - 58 (IFS)
Front (see hilux, but offset rear)
Rear
TJ Wrangler (Danas') - Which dana, there are THOUSANDS of setups, from jeep, chev, ford etc etc, rangin from pissy dana 25's up to full size dana 70's with 80 inch WMS-WMS. I hve a large list of widths, offset and stud patterns i will try to dig up, it lists the more useful ones. Even the wranglers had different Dana's depending on make model Rubicon spec etc :wink:
Front
Rear
Cruiser (40 Series)
Front ~55
Rear ~ 55
Cruiser (60 Series)
Front - ~60
Rear - ~60
Cruiser (70 Series)
Front
Rear
Cruiser (80 Series)
Front - 63
Rear - 63
Patrol MQ
Front -56
Rear - 56
Patrol GQ
Front - ~62
Rear- 62
Some of these are from memory, i will dig up and check what i have noted down, i have every toyota diff except the 40 series sitting round so i will measure them on the weekend too and correct any mistakes.
Layto....
Post Posted: Tue Nov 03, 2009 11:36 pm
Brake to brake widths for different axles. This info will be great for anyone doing an axle conversion.
We should start with the easy ones (Suzukis') .....
The List
I work in Millimetres, it's a bit more accurate than "to the nearest Inch"
LJ50
Front 1130mm
Rear 1140mm
LJ80
Front 1230mm
Rear 1240mm
Sierra NT
Front 1250mm
Rear 1260mm
Sierra WT
Front 1340mm
Rear 1350mm
Vitara
Front 1435mm
Rear 1440mm
Post Posted: Tue Nov 03, 2009 11:55 pm
cheers, Davo.
Layto....
Yep that is what I was saying mate.
And if anyone cares, 80 hubs fit on 60 diffs, and viceversa.
This makes fitting discs to a 60 a tad easier, also a cheap way to (legally) widen a 60 rear. The standard brakes don't fit then though, they do not mix and match.
And the 60's are good offsets for sierra's. (big pumpkin though. :( ), and I should know..... I have some waiting at home for me. :D
Cheers, Davo.
Post Posted: Thu Nov 05, 2009 2:15 pm
WMS to WMS is what I was after :lol:
I have updated to first post with the numbers
Post Posted: Mon Feb 21, 2011 12:20 am
Updated with GV XL7 rear
Post Posted: Mon Feb 21, 2011 12:24 am
maybe a move to good tech would be a good idea..... ;)
Post Posted: Mon Feb 21, 2011 10:47 am
My coily is 1725mm without wheelspacers. 8O :twisted:
Post Posted: Mon Feb 21, 2011 10:55 am
So your axle is wider than a mog diff? I think not. :roll:
Vehicle: SJ50 hardtop!
Post Posted: Mon Feb 21, 2011 10:57 am
I believe gu diffs are 25mm wider per side then gq
NT SJ50
Post Posted: Mon Feb 21, 2011 11:24 am
No, but the wheel track is... side wall to side wall.
Post Posted: Mon Feb 21, 2011 11:36 am
Ok. This thread is about WMS to WMS measurements.
Does anyone know if SV diffs are the same width as SQ GV----> diffs?
Post Posted: Tue Mar 15, 2011 4:22 am
Does any one know what the gv wms to wms is
Post Posted: Tue Mar 15, 2011 5:13 am
The List
LJ50
Front 1130mm
Rear 1140mm
LJ80
Front 1230mm
Rear 1240mm
Sierra NT
Front 1250mm
Rear 1260mm
Sierra WT
Front 1340mm
Rear 1350mm
Vitara
Front 1435mm
Rear 1440mm
Vitara V6
Front
Rear
Jimny
Front
Rear
Grand Vitara
Front
Rear 1510mm
Grand Vitara XL7
Front
Rear 1510mm 8O
Donors
Hilux (79-85)
Front 1397mm
Rear 1397mm
Hilux (86- )
Front 1397mm
Rear 1473mm
Front 1397mm
Rear
Rear Dana 44 1563mm
Cruiser (40 Series)
Front 1447mm
Rear 1397mm
Cruiser (60 Series)
Front 1524mm
Rear 1473mm
Cruiser (70 Series)
Front
Rear
Cruiser (80 Series)
Front 1625mm
Rear 1612mm
Patrol MQ
Front 1422mm
Rear 1422mm
Patrol GQ
Front 1574mm
Rear 1574mm
Vehicle: 2004 SQ625 GV
Post Posted: Wed Mar 16, 2011 7:55 am
The List
LJ50
Front 1130mm
Rear 1140mm
LJ80
Front 1230mm
Rear 1240mm
Sierra NT
Front 1250mm
Rear 1260mm
Sierra WT
Front 1340mm
Rear 1350mm
Vitara
Front 1435mm
Rear 1440mm
Vitara V6
Front
Rear
Jimny
Front
Rear
Grand Vitara
Front
Rear 1510mm
Grand Vitara XL7
Front
Rear 1510mm 8O
Donors
Hilux (79-85)
Front 1397mm
Rear 1397mm
Hilux (86- )
Front 1397mm
Rear 1473mm
Front 1397mm
Rear
Rear Dana 44 1563mm
Cruiser (40 Series)
Front 1447mm
Rear 1397mm
Cruiser (60 Series)
Front 1524mm
Rear 1473mm
Cruiser (70 Series)
Front
Rear
Cruiser (80 Series)
Front 1625mm
Rear 1612mm
Patrol MQ
Front 1422mm
Rear 1422mm
Patrol GQ
Front 1574mm
Rear 1574mm
You thinking 28 spline rear diff to replace the GV 26 spline??? :D
Post Posted: Wed Mar 16, 2011 8:21 am
if you could get other ratios it would be an option.
Post Posted: Wed Mar 16, 2011 8:36 am
Man 4.3 and auto 5.13. Not sure if they changed the crown wheel and pinion sizes. I would have thought they just put bigger axles in. Might be tough gettin a locker though.
Post Posted: Wed Mar 16, 2011 9:30 pm
I thought that the xl7 was wider then the gv
Post Posted: Thu Mar 17, 2011 7:46 am
Just longer. rear body work might be wider but thats it
Post Posted: Sun Apr 17, 2011 10:32 am
bit of a stretch but people wouldn't have weights of these as well?
Post Posted: Fri Dec 23, 2011 10:34 pm
anyone got the WMS of the SV420?
Post Posted: Sun Feb 26, 2012 1:52 pm
anybody know the width of a 70series rear?
Users browsing this forum: No registered users and 59 guests
