It is currently Wed Nov 04, 2026 9:03 pm
Post Posted: Wed Mar 07, 2012 4:36 pm
1999 JIMNY JLX....
Are following switches backlit ?
1. REAR WIPER
2. REAR WASHER
3. REAR DEMISTER
4. CIGARETTE LIGHTER
5. PW SWITCH ON DRIVER'S SIDE
6. PM SWITCH
7. HAZARDS SWITCH
Cheers,
Post Posted: Thu Mar 08, 2012 11:05 am
You can always pull them off and have a look your self,
Post Posted: Thu Mar 08, 2012 11:11 am
Jesus.. :|
Post Posted: Thu Mar 08, 2012 6:09 pm
Blakey, working on our post count ?
Post Posted: Thu Mar 08, 2012 6:32 pm
Depends are you just being lazy??
Takes 2 sec to pull stuff off a Jimny.
if you really must know.
1. REAR WIPER; usually on front wiper stalk so no
2. REAR WASHER; same as above
3. REAR DEMISTER; usually yes as well as in indication light to say its on
4. CIGARETTE LIGHTER; in an old Jimny No
5. PW SWITCH ON DRIVER'S SIDE; guessing that is Power window, age of your car No
6. PM SWITCH; guessing power mirror, age of your car again No
7. HAZARDS SWITCH; age of your car id say most likely not.
things that usually do have back lighting is dash cluster, aircon fan, aircon temp, aircon air direction, demister button
, radio. in newer cars there is more
Happy??
As i said you can always pull them off and have a look, it will give you defiant answer.
Post Posted: Thu Mar 08, 2012 6:39 pm
Mate,
Jimny ('99) rear wiper/washer has two separate switches, it is not on the stalk............to get to them I need to pull the whole front panel off....but thanks for the effort.............
Anyone else with a definate answer ('99 Jimny), would be much appreciated ?
Cheers,
Post Posted: Thu Mar 08, 2012 6:51 pm
another way to tell is to look at the switch to see if they have semi clear plastic for the pictures on them.
Post Posted: Thu Mar 08, 2012 7:03 pm
OK, I will pull them apart (switches) on the weekend to see if the little globes are blown.....................
Post Posted: Fri Mar 09, 2012 9:10 am
i mean just look at them from the outside, if its clearish you should be able to tell.
id sugest replaceing them with LED's if you can, as they last allot longer and you wont have to replace them for pretty much the remaining life of the car.
plus you can choose any colour you want them to be rather then i think its red that they usually are.
Post Posted: Fri Mar 09, 2012 3:56 pm
OK, I will sort it our on the weekend and update thread...
Users browsing this forum: No registered users and 144 guests
