It is currently Fri Nov 13, 2026 2:29 pm
Vehicle: multiple R32's, wtd sierra
Post Posted: Fri Mar 09, 2012 12:21 pm
i was just surfing the net and reading about weber carbs and heir apparent hill climb/descent issue and i found this write up
http://board.marlincrawler.com/index.php?topic=46859.msg588356#msg588356
has anyone seen this before or better yet tried it out?
Post Posted: Fri Mar 09, 2012 12:39 pm
That is a common fix to "improve" the capability of the weber carb but it wont fully cure it on the really steep stuff. The positioning of the float bowl and how the metering system is setup is the inherent issue with them. If you could mount it 90* on the manifold it would run a lot better on the steep stuff!
Lil Foot!
Post Posted: Fri Mar 09, 2012 1:54 pm
If you change the thread title to something like.... "Weber 32/36 vent fix" then it will be findable in a search for other users.
Post Posted: Fri Mar 09, 2012 5:34 pm
good idea, sorted.
Post Posted: Fri Mar 09, 2012 8:01 pm
you mean something like this?
Users browsing this forum: No registered users and 64 guests
