It is currently Thu Nov 05, 2026 4:21 am
Vehicle: chick magnet coily
Post Posted: Mon Mar 12, 2012 4:08 pm
ok so i was wondering what fairly easy mods there are for a coily :?
also is it very hard to fit a bodylift or coil spacers?
and would a solid t'case mount be better or not?
when in doubt... HOLD IT PINNED!!! :)
Vehicle: sierra
Post Posted: Mon Mar 12, 2012 4:24 pm
bl is easy, this is the build section not chat, so is this a build page of yours? if you do a search you may find your answers.
Post Posted: Mon Mar 12, 2012 7:07 pm
where or how do i get to this build section?
Vehicle: 89 Vit. The Desert Rat...
Post Posted: Mon Mar 12, 2012 7:29 pm
For body lift have a look here: viewtopic.php?f=15&t=15518
They come with instructions. As far as coil spacers are concerned they are really easy to fit. At least they were on my vit.
PM Bruce. He I think he sells spacers, not sure about coily's though.
As for legalities in QLD? No idea.. Maybe one of the QLDer's could answer that.
Katherine 2013!
Post Posted: Mon Mar 12, 2012 9:52 pm
I've got coily spacers here. ( they are Bruces brand )
let me know if you need some.
Post Posted: Tue Mar 13, 2012 4:16 am
thanks guys
fatzook: how much do you charge for coil spacers?
also what easy mods ase out there?
Vehicle: 1985 Holden Drover
Post Posted: Tue Mar 13, 2012 5:32 am
Really depends what you define as easy? Cheap? Quick? Simple?
What might be easy for one person might be hard for another.
1989 WT Sierra.
Post Posted: Tue Mar 13, 2012 6:45 am
Basicly any fairly cheap mods that dont involve machining
Would be great
So far iv got:
Removed swaybar
30x10 buckshots
Alloy bar and roll bar
Spotties
Pioneer system
Revers light
And extended bumps
What els am i able to do?
Any help is apreciated
Post Posted: Tue Mar 13, 2012 5:21 pm
body lift is fairly simple but it must be approved in Queensland so it has to go over the pits to ensure it is done correctly.
Post Posted: Tue Mar 13, 2012 7:43 pm
does it cost much?
to get aproved?
Post Posted: Tue Mar 13, 2012 7:48 pm
fully sick coily wrote:
does it cost much?
to get aproved?
Under $250, approval you will need to book into DOT. Bolt on standard tyres, sway bar and a general tidy up of EVERYTHING that isn't in a roadworthy condition 8)
Post Posted: Tue Mar 13, 2012 7:53 pm
its also a good idea to degrease and give everything a good clean before you take it so no oil leaks or any other faults can be found
Post Posted: Tue Mar 13, 2012 8:35 pm
oops!!!
i no longer have stock wheels :(
can i just put legal tyres on my sunraiers?
is that $250 inc bodylift?
Post Posted: Tue Mar 13, 2012 8:41 pm
BL is $220 from this guy 8)
90% sure the DOT appointment is free, but I could be wrong
Post Posted: Tue Mar 13, 2012 8:43 pm
DOT appointment is around $70 per attempt but if you fail generally they don't charge you for a second
Post Posted: Wed Mar 14, 2012 4:14 am
so will it get mod plated?
and can i have this on my car with my p's
( modified vehicle )
Post Posted: Wed Mar 14, 2012 9:43 am
No mod plate, you get a certificate to say it has passed and that has to stay in the vehicle at all times. No mod plates do not effect driving as p plater unless they are performance rated (forced induction, engine swap, etc).
Users browsing this forum: No registered users and 124 guests
