Joined: Sat Jul 30, 2011 12:14 am Posts: 193 Location: perth
Posted: Mon Mar 12, 2012 1:13 am
well just got back from a epic beach trip i split the alloy front diff so these steel diffs will they fit my 99 v6 gv auto? and what other stuff can i do to stop this happerning again will get diff dropbracket was only going up a big hill had to give it a bit of throtle towards the end and bang spilt
Posted: Mon Mar 12, 2012 5:07 pm
ok got a new steel housing diff man says all the guts will fit also fitting a nylon bush now i have lifted my gv about 50mm should i get some drop brackets for the diff?
Posted: Tue Mar 13, 2012 3:10 pm
all good inside went up a steep sand dune dropped the front wheels into some tyre ruts and tried to crawl thru and pop went the housing i knew what is was as soon as i felt it just put it in 2wd and drove out at 20kmh all the way to closest mates house 20 k away
Users browsing this forum: No registered users and 810 guests
