It is currently Thu Oct 22, 2026 12:50 am
Post Posted: Fri Mar 09, 2012 12:20 pm
Have been having trouble with my 1.3ba misfiring and stalling. When i first start engine, everything seems fine, after few minutes warming up it devolps a misfire right thru the rev range, and eventually stalls under 1500rpm. Thought it was a carby problem but have changed carbys and still has exactly same symptoms. After i leave it for 30 min or so it will start fine and idle at 900rpm, but then the gremlins return after few minutes of engine running. I have tried checking valve clearances, changing timing setting on the dizzy, put new rotor and cap on, changing carbs, i guess all thats left is leads and plugs. Any suggestions on what else could be causing this problem?
91Sierra; 2in lift; 2inBL; 6.5s; 31muds;
Post Posted: Fri Mar 09, 2012 3:53 pm
by 'missfire' i take it you mean a steady miss, ie, one cylinder not firing. Sounds like ignition.
when it is missfireing, take each lead off in turn, and see which one makes no difference to the way the engine runs (you will need a second person to hold a steady RPM, since it wont idle)
that way you will have isolated which cylinder is the problem...
try swapping a couple of leads over (both ends) and see if the missfire moves with the lead.
I'd be getting some new plugs before i even worried about further diagnosis anyway.
Post Posted: Fri Mar 09, 2012 4:00 pm
if they are all missing, try another coil, it could be cooked
Vehicle: 90 Vitara
Post Posted: Fri Mar 09, 2012 4:59 pm
Check fuel filter too
Post Posted: Fri Mar 09, 2012 5:16 pm
Yeah got new fuel filter, flushed tank, new air filter as well.
Post Posted: Fri Mar 09, 2012 7:18 pm
Could be a vacuum problem.
Check the carby bolts and manifold are tight.
Check the PCV.
Check the vac adv. diaphragm.
Vehicle: Suzuki/Sierra/1988 SJ50 HiTop
Post Posted: Sat Mar 10, 2012 6:28 am
Yes, sounds like a leak in your intake system somewhere. When its cold, the choke enriches the fuel so the leak is not such a problem leaning out the fuel. I had a similar problem that was a missing plug on a spare manifold vacuum takeoff pipe near cylinder 1. Dunno how the cap fell off! Check all the hoses and doodads connected to vacuum supply from the manifold as well as the manifold bolts. How to test the valves and things is in the shop manual http://www.suzukiinfo.com/
Also check your earthing strap from the B(-) to the engine block. Take it off and re-crimp the eyes because the vibration can eventually loosen the wires. I've replaced my earthing strap with a heavy duty one, plus an additional one to my second battery and coincidentally ever since then I get 10%+ better milage - don't know whether that was related - very strange!
I'm unable to read the rules...
Post Posted: Sat Mar 10, 2012 9:32 am
I had a similar problem recently
From my experience, misfires are usually electrical. It's easy to blame fuel but 9 times out of 10 it will be spark.
Leads, plugs, timing, dizzy cap & rotor first. If you havn't done leads & plugs do them, try a borrowed set of leads from another car, do all 5 first, then one at time to find the crook one.
Check & clean the electrical connections to the earth, coil and resistor if you have one. Coils sometimes breakdown when hot.
In my recent case, it was intemittent, and occured when hot and seemed caused by hard engine deceleration. I exhausted the electrical & fuel (I changed everything including the carby). I think it eneded up being the inlet manifold valve below the carby, Its called the Exhaust return valve (or something similar). Its operated by vacuum. I took it off and cut a shim to cover the exhaust passages and put it back on, to block it off.
So far it seem so be better.
Post Posted: Mon Mar 12, 2012 5:07 pm
Ok, put new coil, leads and plugs in today and still no better. I did notice that when i have a plug lead off, it throws a spark out of the coil lead ( from under the rubber cap on top of coil and arcs on +terminal of coil). Should this be happening?
Post Posted: Mon Mar 12, 2012 5:24 pm
Wats best way to clean pcv? Splash it around it petrol? WD40?
Post Posted: Mon Mar 12, 2012 6:28 pm
Nope 8O
with a plug lead off you might get a spark from the disconnected end of the lead to metal on the car,
Have a look when its dark, with all the leads on check for arc / sparks escaping from the leads etc, this may explain your miss.
Post Posted: Tue Mar 13, 2012 1:15 pm
From my experience, misfires are usually electrical. It's easy to blame fuel but 9 times out of 10 it will be spark...........................................................
So it is usually electrical....... fixed by blocking the non electrical EGR valve... How does that make any sense?
OP:
If you see any arcing at the coil it is probably cracked and needs replacing.
Post Posted: Tue Mar 13, 2012 3:02 pm
Brand new bosch coil put on yesterday. Only sparks at coil when a lead is off one of the spark plugs.
Will a 1.0l coil to dizzy lead fit my 1.3? I borrowed a second set of leads but only the 4 spark plug leads.
Post Posted: Tue Mar 13, 2012 5:53 pm
mine has just started missing today. almost stalled twice driving in traffic. car is driving fine then starts losing power & then starts coughing & farting
then picks up power and away i go again. not sure what to look at first. any suggestions?
Post Posted: Tue Mar 13, 2012 6:14 pm
i should've mentioned this started after filling up with fuel on sunday
Post Posted: Tue Mar 13, 2012 6:33 pm
Fuel filter.
Water in fuel.
Dodgy fuel pump.
Post Posted: Tue Mar 13, 2012 7:50 pm
checked fuel filter and looked pretty clean, might put another one on in the morning to be sure
also found one of the fuel pump hoses was not on properly so see how i go.
Post Posted: Wed Mar 14, 2012 11:53 am
Buy a can of carby cleaner and your problems will dissolve!
 Profile WWW ICQ YIM
Post Posted: Wed Mar 14, 2012 12:16 pm
tried carby cleaner problem still there.
will bit the bullet & rebuild carby as it has never been done.
Users browsing this forum: No registered users and 196 guests
