It is currently Fri Oct 23, 2026 9:03 pm
Post Posted: Tue Mar 13, 2012 4:50 pm
does anybody know if there was a coil pack version of the vitara g16b? (north-south config.)
or did the coil pack engine only come in the baleno (east-west config.) ??
Post Posted: Tue Mar 13, 2012 6:34 pm
As far as I know Vitaras only got coil packs with the J20.
Post Posted: Tue Mar 13, 2012 6:38 pm
okay, cheers.
just looking at doing a g16b swap into my g13bb jimny and need the coilpack motor
Post Posted: Tue Mar 13, 2012 6:44 pm
G16b Grand Vitara?
Post Posted: Tue Mar 13, 2012 6:50 pm
that might be the ticket royce!
just googled it and found this..
http://www.carsales.com.au/private/deta ... 2-12036991
last picture shows the engine, and says g16b in the engine specs...
only problem now is finding an engine outta one...
Post Posted: Tue Mar 13, 2012 6:55 pm
why cant u use the baleno motor??
Post Posted: Tue Mar 13, 2012 6:57 pm
looks like it was only available in the swb, from 98-05.
from what i can find anyway..
Post Posted: Tue Mar 13, 2012 7:01 pm
im not sure if i can or not..
ive fond out from a good source that if i get a g16b coilpack motor, all i would need is basically a long block, and everything from my g13bb would bolt up (manifolds, coolant hoses, swap cam in, etc) and use an adaptor kit to mate it to the gearbox (like g16b into sierra)
and i just assumed that with a baleno being a E-W motor that it wouldnt be a simple swap. thats under the assumption that the the details are about using a N-S motor, which would make sense.
Post Posted: Tue Mar 13, 2012 7:06 pm
That would be my plan! Nothing wrong in making the bal g16b e/w to n/s. Just use ur jim gear,sump,pickup etc and ecu. Need adaptor plate also.. Only difference u may get is stud/bolt location for ac/ps pump.
Post Posted: Tue Mar 13, 2012 7:13 pm
ive considered that.. but thought about some of those things you mentioned like accessory locations/brackets
and one other thing i think would be different is coolant lines to and from radiator..
looks like your using a baleno motor in your lwb build correct?
Post Posted: Tue Mar 13, 2012 8:01 pm
G16b Grand Vitara?
Yep. Got one here. Not sure when they started fitting the coil pack motor to the GV, but mine is an 04 GV motor, and it is most definately a coilpack model.
Post Posted: Tue Mar 13, 2012 8:58 pm
Im using a baleno coilpack g16b in my lwb and my last swb also had one.Alot of differences going from sierra to baleno, but Jim to baleno are more similar to each other.
Post Posted: Tue Mar 13, 2012 9:11 pm
yeah, cheers mate.
i've slowly been figuring out the differences as i research. im going to look for both grand vitara and baleno g16b, and whichever i find first/cheaper ill use.. just need the jimny on the road as ive sold my sierra.
Post Posted: Tue Mar 13, 2012 10:23 pm
I know they have coilpacks and a cam sensor, But do jimnys g13bb run a crank sensor? If not, The normal vit blocks should be avaliable also.
Post Posted: Tue Mar 13, 2012 10:28 pm
haven't checked to be honest. but ive been told that the jimny sump swaps straight onto the g16b coilpack engine. so that would mean it does run a crank sensor. if im correct in assuming that the crank sensor fits into the whole in the sump at the back of the engine?
and in doing that id need a rock cover from a coilpack engine too possibly..
Post Posted: Tue Mar 13, 2012 10:32 pm
Jimnys don't have a crank sensor hole? I was lead to believe they did until i went to buy a jimny sump! No hole..
Baleno and g16b GV's have holes at the front of the crank to pick up/see the teeth on a special crank timing pulley.
Post Posted: Tue Mar 13, 2012 10:46 pm
ill check about the crank sensor next time at work (jimnys at work).
but i was told by a guy at suzistore, whos obviously done the swap in a list of things needed to be swapped that coil packs were included.
so to me that suggests that he used a coilpack motor, which with what your saying would have the crank sensor..
unless i misinterpreted it, and it was something that had to be added?
Post Posted: Tue Mar 13, 2012 10:48 pm
Baleno does. G16B GV does not.
The GV sump has the hole, but the block does not. ie, no crank sensor in sump.
Post Posted: Tue Mar 13, 2012 10:50 pm
so GV g16b would work going by that..
Post Posted: Tue Mar 13, 2012 10:53 pm
If your BB has NO crank sensor, then the GV motor will work easliy.
Having said that, the Baleno motor should work also. Just don't fit the crank sensor.
However if you need a crank sensor, the baleno is the better choice, as it already has one. Otherwise you would need to drill the GV block to accept the sensor, and run a baleno timing pulley with the pickups for the sensor.
Post Posted: Tue Mar 13, 2012 10:57 pm
thanks peter.
ill check that next time im at work. but if i recall rightly it doesnt, as ive had it on the hoist but wasent looking for that so didnt take notice.
and once i know that, ill be on the path to finding the right engine for it!
Post Posted: Tue Mar 13, 2012 11:00 pm
Ratty on here got a sump from the later GVg16b to fit onto his Baleno motor into his sierra. Its a better shape suited to 4wding than the baleno. I knew they had the hole in the sump but didnt know about the no sensor.
The GV's are quite rare.
Post Posted: Tue Mar 13, 2012 11:06 pm
yeah, the fact the swb GV's are rare is the thing that worries me.
i guess if i got a baleno motor and didnt need the crank sensor i could make up a bung for the hole, or bolt the sensor up and cut the wire..
Post Posted: Tue Mar 13, 2012 11:16 pm
The sensor is on the outer rim edge of the sump. So either modify the sump to bolt a sensor in, or make a bung with a normal sump. Not really another option. The sensor has a plug connection. No wires to cut if needed.
Post Posted: Wed Mar 14, 2012 7:29 am
just put any 16 valve bottom end in, put your G13BB head on and job done
Post Posted: Wed Mar 14, 2012 7:41 am
engines done either head gasket or head. thats my reason for the swap..
if its just the gasket ill just change it and get the jimny on the road and do the swap later, but if its the head ill do the engine now..
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 194 guests
