It is currently Tue Nov 03, 2026 7:00 am
Post Posted: Thu Mar 15, 2012 3:39 pm
hey all, would anyone know if front sierra shocks fit rear vitara shocks? because they have a pin a hole joint (whateva ya call it) dont they? cheers bradd
Post Posted: Thu Mar 15, 2012 4:25 pm
I believe they will be too short.
Post Posted: Thu Mar 15, 2012 4:28 pm
what about if its off a 6'' lift kit? if ya know
Post Posted: Thu Mar 15, 2012 4:39 pm
There is no such thing. Any lift of that magnitude will be custom, and ANYTHING could have been done with shock mounts etc, so there is no way to tell you if they will work or not.
Post Posted: Thu Mar 15, 2012 5:18 pm
ok no worries thanks
Post Posted: Fri Mar 16, 2012 3:48 am
Wouldn't they be way to soft as well
I've been told that u need to run a lot stiffer shock in a coil set up then u do with leaves
Post Posted: Fri Mar 16, 2012 10:53 am
yeah that sounds about rite because the shocks in leaves only coushin the ride thanks mate
Post Posted: Fri Mar 16, 2012 12:34 pm
Not nitpicking, but WTF?
Steve
PS yes it is true that leaf cars run less shock valving than coil for the same spring rate, my question is how is the function of a shock different between a coil or leaf car?
Post Posted: Fri Mar 16, 2012 12:46 pm
who you asking?
Post Posted: Fri Mar 16, 2012 1:15 pm
Er, you?
Post Posted: Fri Mar 16, 2012 1:30 pm
umm i dont realy understand what you mean but i thought that the front shocks would be bigger on a sierra because you can get like 4'' lift ones and i thought that they would be a good size for a vitara
Post Posted: Fri Mar 16, 2012 1:38 pm
He means, explain this statement.
Post Posted: Fri Mar 16, 2012 1:56 pm
ohhhhhhhhhhh riteeee hahah my bad :roll: no there is no difference thay both obvisoly absorbe shock but what im saying is that the sierra shocks are abit more softer than the vitara because it is leaf sprung (if that answers your question and if it makes sence haha)
Post Posted: Fri Mar 16, 2012 6:17 pm
Isn't it because the friction between the leaves create there own self dampening to some extent
Post Posted: Sat Mar 17, 2012 11:31 am
Do a search for vitara shocks. I wouldnt be suprised if people were using vn-vs commodore wagon rears in the rear
Post Posted: Sun Mar 18, 2012 12:37 am
mate just go to supercheap and get some vp/vn commodore wagon shocks. these are used by heaps of people and are almost perfect for 40mm/ 2inch lifts
theres a thread called something like 'commodore shocks question' in 'good tech' or have a look in my build thread
Post Posted: Thu Mar 22, 2012 3:52 pm
No worries thanks heaps ill have a look
Post Posted: Thu Mar 22, 2012 7:43 pm
Hey can I plz ask where did u get the rear swaybar from in ur pic above
Post Posted: Thu Mar 22, 2012 8:20 pm
VL sedan I believe is the common (but way to long) shock used
Post Posted: Thu Mar 22, 2012 8:25 pm
GBW, check his build thread for more pics.
I think it might just be a pedders one... seeing it's Red? I asked about it a while ago & Larry posted a few good pics for me. I'm thinking it might be a good way to add some roll stiffness to the floppy bum of the Vitara's & get it to balance out the flex a bit better.
Post Posted: Thu Mar 22, 2012 8:44 pm
The sedan shocks are huge!
Post Posted: Thu Mar 22, 2012 9:18 pm
viewtopic.php?f=17&t=13142
this thread is right on the money, skim through the first few pages for the part numbers and open closed lengths ect
the sway bar is what im assuming to be a pedders one, i acctually took it off as it seemed to just get skull dragged on everything.
tbh i can hardly notice it on or off road.
in flexy ruts and such the rear end is just as soft with or without swaybar in, and on road i can still go fast around tight corners. the only place i think it would be helpful is high speed sweeping bends on country roads or on corrugated dirt roads.
im not saying it does nothing, but it doesnt do much.. maybe a different design would have better results
Post Posted: Fri Mar 23, 2012 6:46 am
I think Joe needs to make some for vits like the one he did for kennys lj
Post Posted: Fri Mar 23, 2012 10:13 am
If it was mounted above the housing id just leave it but its more of a disadvantage to me. Its just a bad design for 4wding
Users browsing this forum: No registered users and 124 guests
