It is currently Mon Oct 19, 2026 10:15 am
Post Posted: Wed Mar 14, 2012 10:34 pm
I remember a few years ago in Vic a taco was good enough in place of a speedo. Is this still the case?
I bought a new speedo cable because it was broken but as I put it in I noticed the little lug in the transfer is broken off. I really don't want to split the case to fix it. So will just the taco pass?
Post Posted: Wed Mar 14, 2012 10:48 pm
In a sierra tcase you dont have to split it to replace the drive gear. Get a new gear, spend 5mins under the vehicle and done. No worries then with your speedo and a roady.
Lil Foot!
Post Posted: Wed Mar 14, 2012 10:59 pm
Yes, Undo the bolt and it should pull out..if its broken off its going to be a pain..
Some people have trouble with them even with the lug to grip and pull out..
Vehicle: LWB Sierra & XL7
Post Posted: Thu Mar 15, 2012 8:22 am
mmm Taco's.
As you may know, Tachometer's only indicate the revolutions per minute / hour of the engine (depending how many zero's are on teh tacho) not speed. I'm not 100% certain of the rules reg's in Vic, but I would say it is very unlikely that it would be legal to use a tacho as a speed indicator in any state or territory in aus.
'92 Vitara & Camper trailer
Post Posted: Thu Mar 15, 2012 9:03 am
I went for Rego without a speedo once.... I was so use to it I had forgotten about it till after It passed and I was driving home...
Post Posted: Thu Mar 15, 2012 9:58 am
Speedo IS a requirement for compliance but the chances of a not working speedo being picked up during the inspection are slim if the car is unregistered because it can't be test driven unless the garage has a trade plate.
Post Posted: Thu Mar 15, 2012 10:30 pm
So if I pull the speedo cable out that that little peice with the lug should pull out?
Thanx for all the replys
Vehicle: Clown Car..
Post Posted: Fri Mar 16, 2012 6:28 am
Yep!
http://zukiworld.com/month_070102/featu ... nstall.htm
http://blogpdf.com/suzuki-samurai-6.5-t ... it-4970110
Post Posted: Fri Mar 16, 2012 6:33 am
Wow. Thanx for the detail. Where abouts can I get a new one of those?
Post Posted: Fri Mar 16, 2012 6:39 am
Put up a wanted post, someone might have one spare, or try wreckers. Unsure if they can be bought new?
Users browsing this forum: DamoRed83, Google [Bot] and 242 guests
