It is currently Fri Oct 30, 2026 7:51 pm
Post Posted: Tue Mar 16, 2010 10:13 pm
awhile ago this happened to my rear diff
i made a template and got some steel cut and welded them on
the mounts are now 10mm thick, they have been on the car for around 6000ks and no problems
Post Posted: Wed Mar 17, 2010 12:18 am
Good work mate 8)
Post Posted: Wed Mar 17, 2010 11:48 pm
Jimny?
( I have recently been studying the Jimny setup.)
Ah not Jimny. Its a Coily! :lol: Just noticed fuel hose guard..Very similar though.
Post Posted: Thu Mar 18, 2010 9:36 pm
yeah its a coily, they do have a few things in common with the jimny, but not a lot.
Post Posted: Fri Mar 19, 2010 1:55 am
next time it will just tear the diff tube :D
Post Posted: Sat Mar 20, 2010 4:28 pm
hopefully not :oops:
Post Posted: Sat Mar 20, 2010 5:21 pm
my little brace from the trailing arm mount to the diff tube still let it twist a tiny bit but made it strong enough :)
Post Posted: Sat Mar 20, 2010 8:19 pm
That's when you just add more steal to the tube.
I have similiar strenghtened mounts, except more added to the back section and the rear mounting hole lowered to turn the whole housing back around level so the pinion flange is still at the same angle as the rear trasnfer output.
Front has been done the same and for castor correction.
Vehicle: chick magnet coily
Post Posted: Fri Mar 16, 2012 1:15 pm
did you have to remove anything from the diff to weld them on or did you do it on the car?
when in doubt... HOLD IT PINNED!!! :)
Post Posted: Fri Mar 16, 2012 1:50 pm
I pulled mine out.
Post Posted: Mon Mar 19, 2012 5:41 pm
I pulled it out of the car, but left it assembled for welding. The next day i did pull it apart to inspect axles and the centre.
Post Posted: Mon Mar 19, 2012 6:10 pm
jonno_racing wrote:
I pulled mine out.
What about the diff :rofl: :rofl:
Post Posted: Thu Mar 22, 2012 6:57 pm
Rusho wrote:
jonno_racing wrote:
I pulled mine out.
The Rush brings the funnniiieessss! pompoms
Post Posted: Thu Mar 22, 2012 7:00 pm
ZookiMonsta wrote:
Rusho wrote:
jonno_racing wrote:
I pulled mine out.
It's what I do :mrgreen:
Post Posted: Thu Mar 22, 2012 10:44 pm
Rusho wrote:
ZookiMonsta wrote:
Rusho wrote:
jonno_racing wrote:
I pulled mine out.
That.....
And shit yourself so bad in the back seat of a moving car, that ALL of the occupants are gasping for air with their heads out the window at 70kph, even though there were 2 PoPo paddy wagons following :gross:
:thefinger:
