It is currently Mon Oct 19, 2026 7:49 pm
Post Posted: Thu Mar 15, 2012 10:47 pm
I need some pics of how the seatbelt cable that hangs out the back on a Maruti tray back conected to the tray. The Original way would be the ideal but for you guys that have changed your tray have you had any trouble with a roadworthy?
Post Posted: Fri Mar 16, 2012 8:51 am
Somebody!!!!?????
Post Posted: Fri Mar 16, 2012 9:04 am
If you use your lovely manners someone might help you.
Vehicle: '96 LWB trayback
Post Posted: Fri Mar 16, 2012 9:15 am
It just bolts through the tray upright with a m8 bolt from memory. Can get pics by the end of the weekend wheb im home if still needed
Post Posted: Fri Mar 16, 2012 10:15 am
Thanx mate. I would appreciate that.
Vehicle: 4wd
Post Posted: Fri Mar 16, 2012 5:52 pm
I have some in my thread, do a search.
Watch out or you'll get sued.
Post Posted: Sat Mar 17, 2012 4:24 am
Old mate goodtime seems to be going through some badtimes. Regards sent.
As you others Thanx for your help.
Vehicle: MG410 1.6efi broken rear diff
Post Posted: Sat Mar 17, 2012 7:18 am
I used high quality chain fed thru PVC tub bolted to tray
Vehicle: '94 suzuki maruti
Post Posted: Sat Mar 17, 2012 7:31 pm
what is the purpose of this chain anyway?
Post Posted: Sat Mar 17, 2012 8:55 pm
I used the chain to replace the seat belt bracket,as the metal bracket or mounting point on tray will crack do to flexing over time.it should be noted the metal bracket was designed for Single frame (ute body) not for seperate tray
Post Posted: Sat Mar 17, 2012 10:18 pm
Have you googled "maruti trayback"? It is surprising how many pics of Sheps junk turn up.
Post Posted: Sat Mar 17, 2012 10:23 pm
Yeah I have. I can't find one photo of the bracket. I would just make something up but my roadworthy guy wants it to look like the original. So any photos would be very helpful.
Cheers for the help
Post Posted: Sat Mar 17, 2012 10:36 pm
see the brackets running from the cab to the tray...
Post Posted: Sat Mar 17, 2012 11:16 pm
I may have picture on PC if I find it I'll post it.
The bracket is only a steel tube thats been flatten into a tab at each
end,with holes the same diameter as seat belt bolt at either end.
Post Posted: Sun Mar 18, 2012 8:16 am
this what your chasing mate?
Post Posted: Sun Mar 18, 2012 1:45 pm
That's the one. Thanx for that. Is that the original?
Post Posted: Sun Mar 18, 2012 2:10 pm
not sure sorry, i've only owned this car less than 2 months... but AFAIK it is. if not, it uses original bolt holes...
Vehicle: Sj70 tintop
Post Posted: Sun Mar 18, 2012 2:21 pm
yep thats the original factory setup!!
Sj70 tintop
Vehicle: 4wd
Post Posted: Sun Mar 18, 2012 3:32 pm
No it's not.
Post Posted: Sun Mar 18, 2012 3:43 pm
stockman wrote:
No it's not.
post pics of your old set up then :roll:
Post Posted: Sun Mar 18, 2012 6:55 pm
stockman wrote:
No it's not.
yes it is.
standard maruti tray and standard mount.
:kissmyarse:
Sj70 tintop
Vehicle: 4wd
Post Posted: Sun Mar 18, 2012 7:07 pm
Maruti never produced a factory trayback, they were all butchered to trays when they arrived here. :roll:
Post Posted: Sun Mar 18, 2012 7:08 pm
Correct, they were all well back/styleside till they arrived in melbourne.
Maruti's cab chassis were fitted with at least 3 different tray styles that I know of. That mount looks nothing like my '95.
Post Posted: Sun Mar 18, 2012 7:33 pm
They used the Original Piller Support Tube with one end Bent 90 deg to to bolt to External Tray.These were fabricated from Original Parts when the Ute back was Removed, I have 4 in my Shed in Sydney but I am in WA at Present
Post Posted: Sun Mar 18, 2012 11:27 pm
My 95 had nothing of the sort. That sounds dodgy as!
Post Posted: Sun Mar 18, 2012 11:47 pm
Yeah that's why I made my own with high tensile chain as they use to crack from flexing
Post Posted: Mon Mar 19, 2012 1:14 pm
That photo that Whincup put up is exactly what I needed. Mine has the same stainless cable hanging out the cab but all I needed was a way to conect it to the tray that looks kind of original. So Thanx to all
Users browsing this forum: No registered users and 235 guests
