It is currently Fri Nov 13, 2026 11:48 am
Vehicle: chick magnet coily
Post Posted: Thu Mar 15, 2012 6:22 am
hey everyone,
just wondering what ''flipped rims'' are or how you get/make them :?
when in doubt... HOLD IT PINNED!!! :)
Post Posted: Thu Mar 15, 2012 7:16 am
When you have big tyres sometimes you need a big rim offset which isnt sold out of the factory. So some fabricators cut the centre out of the rim and reweld it in with a big offset. Many 4wd shops and tyre places will do it.
I love lamp
Post Posted: Thu Mar 15, 2012 8:29 am
Does it cost alot?
Post Posted: Thu Mar 15, 2012 8:43 am
Normally bout 60 bucks or so a wheel
I love lamp
Post Posted: Thu Mar 15, 2012 11:08 am
PM Fatzook off here, he can do it for you.
Post Posted: Thu Mar 15, 2012 12:31 pm
Negative.....this bloke will 8)
memberlist.php?mode=viewprofile&u=2987
Post Posted: Thu Mar 15, 2012 12:56 pm
How much do you charge?
Post Posted: Thu Mar 15, 2012 12:59 pm
He charges $50 a wheel
Post Posted: Sat Mar 17, 2012 11:09 am
also do i need longer shocks if i run spring spacers?
Post Posted: Sat Mar 17, 2012 5:19 pm
Take ur shocks out and flex it up and measure eye to eye and see if ur shocks meet the measuresments. Ideally you want about 30 mm either side just to be safe. Ie your shock will close up 30mm more than ur closed length and open 30 mm more than ur open length.
I love lamp
Post Posted: Sun Mar 18, 2012 4:03 pm
What if i put 30mm extended bumps with 30mm coil spacers?
Post Posted: Sun Mar 18, 2012 4:07 pm
what are you going to do about the limited options for extended front shocks available for the coily?
if you want more height you'll be better off with a bodylift or buy a leafy.
Post Posted: Sun Mar 18, 2012 4:21 pm
Struts :roll:
Post Posted: Sun Mar 18, 2012 4:36 pm
sorry i'm not up to speed with the gayness of coilys & i doubt old mate fully_sick would know what the difference is between a strut & shock
Post Posted: Sun Mar 18, 2012 4:45 pm
:rofl: :rofl:
Post Posted: Mon Mar 19, 2012 4:34 am
strut
Post Posted: Mon Mar 19, 2012 4:35 am
shock
Post Posted: Mon Mar 19, 2012 4:36 am
:thefinger: :thefinger: :thefinger: :thefinger: :thefinger: :thefinger: :thefinger: :thefinger: :thefinger: :thefinger: :thefinger: :thefinger: :thefinger: :thefinger: :thefinger:
Post Posted: Thu Mar 22, 2012 1:28 pm
Hi Fully sick coily, mate with a coily the standard rims have more positive offset than with a leafy (i.e less dish than a leafy) so even running a set of standard leafy rims makes a big differenc to the look, they will just about stick out past your guards. On leafy's it is common for people to run 15x7 F100 offset (-13), on a coily they will look mega wide and require added rubber flare extensions. I would try aset of WT leafy rims for starters, you should get a set very cheap and they will look considerably wider on your car.
Post Posted: Fri Mar 23, 2012 4:34 am
thanks,
at the moment i got 15x8 sunraisias with 30x9.5 maxxis buckshots and they stick out a bit
but they dont scrub on any thing (its not lifted yet :()
so i will have to put sum rubber flares on soon
any recomendations?
Post Posted: Fri Mar 23, 2012 8:32 am
any recomendations?
Get a narrower rim!
Post Posted: Fri Mar 23, 2012 7:07 pm
But i just bought these :(
Post Posted: Fri Mar 23, 2012 11:15 pm
any recomendations?
Get a narrower rim!
What this bloke said :)
Post Posted: Sat Mar 24, 2012 3:33 am
Then buy a bigger tyre to fit them.
Post Posted: Sat Mar 24, 2012 6:46 am
Why a bigger tyre?
Post Posted: Sat Mar 24, 2012 7:07 am
Why a bigger tyre?
Ideally a 15x7' rim is all you need for a 30x9.5 tyre. A 15x8' rim is for 31x10 or even a 33' tyre.
Users browsing this forum: No registered users and 32 guests
