It is currently Tue Nov 03, 2026 11:29 pm
Post Posted: Fri Mar 16, 2012 1:32 pm
Have a question. Did a search but it was a bit conduluded.
I want to put WT diffs under my 1 liter tip top (84) model. Can I use 1.3 NT center and carrier in the WT housing? Will the axels still slot in?
I like the 4.3 reduction I have now in the 1 liter NT and want to keep it roughly the same.
What's my other options.
Vehicle: Sold zuk got a Bt50
Post Posted: Sat Mar 17, 2012 4:16 pm
yep thats what i got in mine NT center in wt housing ;)
bt50 now but still love the zooks
Post Posted: Sun Mar 18, 2012 3:45 pm
Your 1 litre will have 4.1:1 diffs right now, NT 1.3l is 3.9:1.
To use WT housings you have to cut off the old spring perches and weld new ones on to suit the narrower spring spacing.
I think you'l need some longer U bolts too.
Post Posted: Mon Mar 19, 2012 8:34 am
Sheps selling me his WT diffs with NT spacing. I wanted to run the higher ratio 1.3 NT diffs. Thanks for the replies.
Post Posted: Mon Mar 19, 2012 9:13 am
Certainly run the NT diff centres, you'll need to do some funky stuff to the tailshafts to run WT stuff.... Or just replace the flanges.
Post Posted: Mon Mar 19, 2012 9:33 am
Comes with his tail shafts. All I need to do us run a swb rear shaft. I have the switched 1 liter case and already have a 1.3 and 5 speed in it. Should be really straight forward.
Users browsing this forum: No registered users and 22 guests
