It is currently Mon Oct 19, 2026 10:08 pm
Vehicle: 95 sj70 and 78 lj81
Post Posted: Mon Mar 19, 2012 8:21 am
There was a new Hilux (PARR plates) at TT that had coilovers all round and registered in QLD. Wonder if you could do it to a zook and get it legal?
Post Posted: Mon Mar 19, 2012 8:44 am
Fatzook has a ute with coilovers, I think he is planning it to be registered QLD
I have a lwb to be registered in nsw with coilovers
Most roadcars technically have coilovers!
Post Posted: Mon Mar 19, 2012 8:51 am
It doesn't really matter what medium is used for springing - coil overs, separate spring/shock, airbags, whatever- you're designing a link suspension and will need to comply with sound design and construction principles. A coil over is just a means to an end. The coil over is neither legal or illegal, it's all about what it's being attached to.
Link suspensions and coil overs are expensive. You need to know what you need them to do. IMHO they offer lots of tunability and have some packaging benefits, but IMHO most of their advantage over a separate coil/shock is evident at high speed, not something that's very relevant for a Sierra.
Post Posted: Mon Mar 19, 2012 8:11 pm
The main aim is for a softer ride. I'm sure a good setup would give this and have good flex as well. I plan to research this more and see if its worth doing.
Post Posted: Mon Mar 19, 2012 8:16 pm
It was parked outside the Pretty Princess tent....enough said pompoms
Post Posted: Mon Mar 19, 2012 8:40 pm
burls wrote:
There was a new Hilux (PARR plates) at TT that had coilovers in the front
Coil rear.
Post Posted: Mon Mar 19, 2012 8:51 pm
SierraDan wrote:
Coil rear.
Arent they 'coilovers' or Machpherson strut in the front from factory ?
Made in JP. Built in WA.
Post Posted: Mon Mar 19, 2012 8:53 pm
Red89 wrote:
SierraDan wrote:
Coil rear.
they're coilovers in the front, PARR's hilux has had a SAS & plenty more done to it by Buds Customs.
http://www.outerlimits4x4.com/viewtopic ... x#p2088032
Users browsing this forum: No registered users and 224 guests
