It is currently Thu Jul 23, 2026 10:52 am
Post new topic Reply to topic  [ 101 posts ]  Go to page Previous  1, 2, 3, 4  Next
Post Posted: Sat Sep 26, 2009 12:18 pm
these are the same gearbox that run in some of the toyotas, jeeps and quite a few other things. you could sell them to the jeep boys too no doubt.
Vehicle: 1999 Jimny
Post Posted: Sat Sep 26, 2009 5:22 pm
was looking at one from an early cressida, wonder if they were comp controlled???????? But I guess it don't have the torque convertor lock up either.
Post Posted: Fri Oct 09, 2009 6:16 pm
Hey guys,
Here's what I've done and what I know hope it helps you guys out.
A small microcontroller can be programmed to shift the Aisin-Warner transmissions. The downfall of 5V microcontrollers is they are suseptable to 12V RF interference, causing ghost shifting.
I have used a 12V Omron PLC to give me manual shift control and torque converter lock up, had the shift button/switches mounted on the steering wheel, very cool.
I use a shifter that switch two micro switches with a rod/rail for 1-4, very simple and easy to make. Well if you have a mill and a lathe anyway. I also have a switch to choose between letting the factory computer shift the trans of my manual shifter.
Two toggle switches can be used for 1-4 shifting as a cheap way into manual control.
There are Jeeps, Toyotas, Suzukis, Isuzus, Lexus and Mitsubishis that have Aisin-Warner 30-40LE and their variants in them.
Solenoid shift sequence is:
Gear Sol#1 Sol#2
1st ON OFF
2nd ON ON
3rd OFF ON
4th OFF OFF
Rory D.
"Automatic to manual in less than a secon
Post Posted: Sat Nov 26, 2011 11:05 am
:goodtech:
Post Posted: Sat Nov 26, 2011 11:10 am
:goodtech:
there are a lot of gaps in the info :wink: hopefully joe will finish it off one day.
actually next week would be good as i am about start putting the 4 speed in my awesome car :wink:
Post Posted: Sat Nov 26, 2011 11:13 am
joe lists the adaptor in the business directory. http://www.auszookers.com/index.php?nam ... ic&t=20147
Post Posted: Sun Nov 27, 2011 11:03 pm
so after reading this thread would i be correct in saying that the AW-4 can be used witout the factory G16B ECU (as i'm now running a stand alone haltech E6K ecu) do all AW-4's use there own auto computer? and all i need to supply the auto ecu is a tps signal ?
i'm using a GM (commodore) TPS switch on my G16 engine, would i get away with sending that TPS signal to the auto ecu ? should be a similar 5V regulated signal like suzuki sensors.
has anybody put more than factory power through the AW-4 auto ? mines doing 145HP ATW's currently, would be a shame to do the conversion and it not cope with the HP and torque increase.
Post Posted: Sun Nov 27, 2011 11:09 pm
A quick google tells you they run them in jeeps. So they must handle more power with ease.
Post Posted: Sun Nov 27, 2011 11:14 pm
If only it was as simple as that. The ECU converts the TPS signal to 4-bit Gray code that is fed into the TCM. I'm currently working on a unit that intercepts a TPS signal and converts it into this Gray code for the stock TCM to function properly for mnemonix so he can run an auto with this aftermarket ECU.
Dan
Lil Foot!
Post Posted: Sun Nov 27, 2011 11:16 pm
i'm guessing that whilst they might be the same externally they might be spec'd differently internally ie: clutch packs and bands material.
correct me somebody if i'm wrong but i'm pretty sure that was the case with the trimatic's that they made diffent clutch pack setups for v6 and v8 versions.
Post Posted: Mon Nov 28, 2011 12:02 am
Dan
if you coud mate this work you would become a very popular bloke on this site. whilst i'm not currently ready to do this conversion right now i would like to do this in the future i think it would greatly improve tha way my car gets all that power to the ground :)
Post Posted: Thu Dec 01, 2011 9:19 pm
had a search but cant find much, so this is prob the thread for it.
For the people who have an auto in your sierra with a Sierra TCase
How long is the jackshaft from the face of the sierra TC flange to the
output shaft on the auto?
Im donw to about 85mm 8O 8O 8O
Post Posted: Wed Dec 07, 2011 7:37 pm
Dan
The TCM that I have has only one pin for TPS (TH) are you saying that the gray code is sent serially? There is also a single pin for coolant temperature (WT).
2000 Suzuki Vitara 1.6 8V
1986 Suzuki SJ413K
Post Posted: Wed Dec 07, 2011 7:47 pm
Gear Sol#1 Sol#2
1st ON OFF
2nd ON ON
3rd OFF ON
4th OFF OFF
While I'm on the subject, what does solenoid three do?
1986 Suzuki SJ413K
Post Posted: Wed Dec 07, 2011 11:15 pm
Rhinoman wrote:
Dan
I have got a vitara TCM now as well. These do run a single TPS and WT pins. After more research it seems that the AW4 behind Suzuki's, Toyota's and Jeep's all seem to run totally different styles of TCM inputs. Bit bizarre :?
Found out now that it's the Toyota TCM that uses the gray code input.
Doesn't solenoid 3 control the lockup convertor?
Lil Foot!
Post Posted: Thu Dec 08, 2011 7:11 am
I have to say that I know hardly anything about autos, they are uncommon over here except in upmarket models and in some imports. I've been scouring the internet for info and from what I can ascertain the TPS signal is actually the idle switch (or its inverse). WT is a logic level but I haven't deternmined the temperture at which it switches or its polarity.
The code seems to indicate that the solenoid switching pattern is simply the inverse of the shift switch pattern.
Looking at the code I think I made an error with the schematic for the TCM so I need to look at that again, maybe it will become a bit clearer.
The third solenoid is the lock up converter. The schematic only shows them as S1,S2 and S3 so which one is which? on the processor port they are arranged S1,S3,S2.
1986 Suzuki SJ413K
Vehicle: '96 LWB trayback
Post Posted: Thu Dec 08, 2011 9:34 am
Im down to about 85mm
My AW4 is sitting beside the zook ready to go in. Off the top of my head the box is around 15cm longer than the 5speed manual, measured from belhousing to the rear of Joes output adaptor.
I'm expecting the jackshaft to be around 125mm.
Post Posted: Thu Dec 08, 2011 9:04 pm
JrZook wrote:
Rhinoman wrote:
Dan
did you get my P.M. ??
Post Posted: Thu Dec 08, 2011 10:18 pm
Rhinoman wrote:
Gear Sol#1 Sol#2
1st ON OFF
2nd ON ON
3rd OFF ON
4th OFF OFF
Solenoid #3 is the torque converter lockup - the AW4 is also used on the Mitsubishi Pajero iO (or Pinin in Europe) - I have the service manuals, including the pin outs, etc. for the Mitsubishi TCU - just let me know if there's anything else I can help with.
Post Posted: Fri Mar 23, 2012 9:23 am
Can anyone tell me what this plug is and what it does?
It is on the passenger side of the AW4 auto.
As you may be able to see the wires have been crushed at some stage and are now cut through
I was hoping that it is something I dont need but Im thinking its prob to a solenoid so it will have to stay for sure??
Post Posted: Mon Mar 26, 2012 7:22 am
Anyone know??
Post Posted: Mon Mar 26, 2012 7:31 am
I'll try to remember to face a look in the fsm when I get home tonight.
Steve
Post Posted: Mon Mar 26, 2012 8:46 am
Thanks Steve
Post Posted: Tue Mar 27, 2012 5:59 pm
Just checked the FSM,
It's the A/T Shift Solenoid wiring. You will 100% have to rewire that plug or you won't be shifting gears.
Steve
Post Posted: Tue Mar 27, 2012 7:43 pm
DOH!
Yeah I guess the hunch was correct, Thanks Steve.
Now lets hope the plug comes apart so i can run new wires!
Otherwise its gonna be a mongrel job!
Post Posted: Sun Apr 01, 2012 11:09 pm
So just wondering if you had a baleno with auto ecu will it run this?
My Maruti build, Click WWW
Post Posted: Sun Apr 01, 2012 11:52 pm
Maybe....... if you have the TCM and wiring aswell. I'm guessing all of the unwanted wires have been removed from your baleno loom already, so you would need to pieve it all back together if there was even a chance of getting it to work with the AW4.
Although the Baleno never ran anAW4, so I don't like your chances.
Post Posted: Mon Apr 02, 2012 6:55 am
Me neither.
It would require whichever gearbox the Baleno runs to have exactly the same switching logic as an AW-4. It would take heaps of research and I think some trial and error to work out if it was even possible.
It is possible to run a Baleno (or Jimny) ECU and send the correct information to the vitara AW-4 TCC to get it to work properly - Doof is setup like this in the club, and runs and shifts well.
Post Posted: Mon Apr 30, 2012 6:21 pm
what sorta info would you need to figure out how to make the tcm recognise the inputs from a j20a Dan?
Post Posted: Mon Apr 30, 2012 6:51 pm
I need an AW4 and TCM in a vehicle running with the wiring accessible so I can probe it out. Know of any I could suss out?
mnemonix have given me a shit-ton of info on the AW4 as he also requires an interface for his aftermarket comp to run it. Only issue is that the info is a bit contradictory and doesn't exactly tell me what I need about the Vit AW4 auto and TCM. Note: It does matter which TCM you get with it as I'm led to believe that the Toyota/Jeep have controlling scheme.
Dan
Lil Foot!
Users browsing this forum: No registered users and 80 guests
