It is currently Sun Oct 04, 2026 9:30 am
Post Posted: Tue Mar 24, 2009 11:14 pm
picked up some ome rear springs for my RUF today.
can someone tell me is there a left and right side on these??
Im assuming not as they both carry the same part no's
reason I ask is the rancho's they replace had left and right sides.
cheers andrew
Post Posted: Tue Mar 24, 2009 11:17 pm
Are they new ones?
I usually put them side by side and the one that is taller goes on the drivers side.
Post Posted: Tue Mar 24, 2009 11:21 pm
yep new I bought 4 new rears. I thought the same but they all sit identical.
thanks bruce
Post Posted: Tue Mar 24, 2009 11:24 pm
good looking springs though pulled the pack apart to get the main leaf out for spring hanger setup , the ome main leaf is 15mm longer than the rancho and has heaps better droop.
Post Posted: Tue Mar 24, 2009 11:35 pm
As far as i'm aware they stopped doing left and right springs.
Post Posted: Tue Mar 24, 2009 11:36 pm
longer............gee :wink: .........i wonder who convinced them to do that....................... :D
Post Posted: Tue Mar 24, 2009 11:38 pm
how long have they been longer joe? and the rear springs dont have left and right sides it is only front springs that do that
Post Posted: Wed Mar 25, 2009 3:52 am
is ome definately the way to go for ruf? or would you reckomend efs or king spring?? i am chasing good flex and obviously a comfy rise. not so concerned about load carrying..
Post Posted: Wed Mar 25, 2009 9:55 am
efs and king springs are a much stiffer spring than the OME's, so yes, if you are going to do a ruf, get ome's. Make sure you do specify you want the softer rated springs, as they do make a heavy duty spring as well.
Post Posted: Wed Mar 25, 2009 10:43 pm
I disagree.
OME HD rears have a full length 2nd leaf that goes a LONG way to prevent springs bending.
I've set up more RUF cars than I care to remember and I'd never recommend anything other than HD leaves.
Cars with a light front end can run 3 leaves, heavy cars need 4 leaves.
Post Posted: Thu Mar 26, 2009 12:01 am
I disagree.
steves right I rang ARB today to check and was told the difference is only the number of leafs in the pack not a leaf rate difference.
Post Posted: Thu Mar 26, 2009 12:18 am
Well I stand corrected :oops: I'm only going off my experience. My nephew has King Springs and my brother has EFS springs in their zooks, and they both have a totally differant ride to mine with the OME's. I do have the softer rated springs (but I hav'nt done a RUF) and it's pretty smooth to drive and flexes up pretty well offroad.
Users browsing this forum: No registered users and 176 guests
