It is currently Tue Sep 22, 2026 4:46 am
Post Posted: Thu Apr 19, 2012 8:20 am
hey im in need to replace my engine oil and diff oils and was just wondering what people use and recommend thanks.
Post Posted: Thu Apr 19, 2012 8:32 am
That depends on quite a few things.
What sort of car is it? How many kms on the engine? Is it using oil? Do you know its service history?
I usually use a diesel oil every 3 services, as it contains alot more detergents in it for removing carbon build up. The downside to this is that it can remove carbon buildup from around your motors seals, allowing oil to leak past them if not in good condition.
But generally speaking, you just use what is recommended by the manufacturer of the vehicle. Should be in the owners manual.
Post Posted: Thu Apr 19, 2012 8:36 am
its a 92 sierra. the engine has 192kms on it and it is using a bit of oil but not much at all, and it blows a bit of smoke, i have no idea off the service history.
i was going to go with a thicker oil for older engines and was going to put stop smoke in the oil also to try and stop the amount of smoke that it pushes out.
Post Posted: Thu Apr 19, 2012 9:08 am
Yep. Sounds like a good candidate for a slightly thicker oil. 20w-50 should be fine. If thats no good, try a 60 weight at your next service.
Post Posted: Thu Apr 19, 2012 10:49 am
yup that is what im going to go for, thanks for your help. and also do you have any idea about diff oil?
Post Posted: Thu Apr 19, 2012 11:26 pm
Manual says API GL-5 SAE 75 or 80W-90 gear oil, a few people worth listening to on here (like the bloke above) recommend an LSD oil whether you're locked or not.
Users browsing this forum: No registered users and 208 guests
