It is currently Wed Aug 05, 2026 3:06 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
Post Posted: Mon Apr 23, 2012 2:42 pm
hey all, im kinda sorta new to this still.
and i was just wondering how would you recommend wiring up some rock lights underneath the car? and what would you recommend me on using ? cheers.
Post Posted: Mon Apr 23, 2012 2:45 pm
Fix the light under the car. Run some wires to a relay.
Fix a switch to the dash.
Run wire from fused source to the switch, then relay.
Bosch mini relay 30A will be plenty if you use small wattage lights.
EG: 4 X 55Watt lights = 220Watts total.
220Watts divided by 12Volts = 18.3Amps.
Run 25Amp cable and you'll be sweet.
Vehicle: 1985 Holden Drover
Post Posted: Mon Apr 23, 2012 2:54 pm
Also depends what lights you want to run too, if you want to go the LED strip option or the normal globes?
1989 WT Sierra.
Post Posted: Mon Apr 23, 2012 2:58 pm
to me these http://www.pirate4x4.com/forum/showthread.php?t=1058739 look really good.
Post Posted: Mon Apr 23, 2012 3:12 pm
i was going to go for normal globes
Post Posted: Mon Apr 23, 2012 3:23 pm
and cheers for that want33s
Post Posted: Mon Apr 23, 2012 3:35 pm
normal globes are going to be prone to damage from flying rocks stocks and mud.
Post Posted: Mon Apr 23, 2012 3:40 pm
yes this is very true, well for the ones in the link you posted would i still have to do the sorta same thing as what want33s said for the wiring up of them?
Post Posted: Mon Apr 23, 2012 3:49 pm
yep, pretty sure that will be fine.
Vehicle: nt sierra
Post Posted: Mon Apr 23, 2012 4:20 pm
atari built one that was better than that.IMO.
ta da http://www.auszookers.com/forum/viewtopic.php?f=14&t=20363&hilit=atari+rock+lights
alot less wire work/feeding through panels n shit.
Post Posted: Mon Apr 23, 2012 5:43 pm
Led all the way, cheap, low power consumption, compact. Would be crazy going halogen lights
Post Posted: Mon Apr 23, 2012 6:37 pm
LED's are GETTING cheap, DO have very low power consumption and ARE compact, but that is the problem I found with them.
The smaller the light the easier it is reduced to darkness by a covering of mud. The bigger the light, the less often you need to wipe it clean.
I ran 6 supercrap 55W egg sized lights for ages, they were so good for crawling I turned the headlights down to parkers. A good budget solution.
Buggy will be LED's but instead of 6 lights I'll have about 30.
Post Posted: Mon Apr 23, 2012 7:07 pm
I'm going to edge towards being a hater here, but I think for most conditions rock lights are a touch, well, ghey.
Thing is, rock lights aren't for the driver - they are for the spotters when you are in super technical terrain. If your spotters have quality torches they make rock lights much less necessary.
I've been in a couple of situations where rock lights would have been useful... but they really are for very technical conditions, not for going for a "night drive"
If you find yourself in the position where you are calling to your spotters "how far is the LHR from dropping off that ledge" or "how far can I back up before dropping off" (and they are struggling to see) then maybe they are a reasonable investment. I certainly can't justify them. Carry a couple of good quality LED torches. - I scored two quality LED torches from Costco for $25 (Cree LED :armsup:) -had them to your spotters and they will be ab;e to help you far more than some lights under the car that may or may not work/be dirty or broken/put the light where you want it.
just my 2C.. I thought I wanted them once.
Post Posted: Mon Apr 23, 2012 7:13 pm
They're not really useful on a normal track with all kinds of terrains and dirt and crap.
But i love mine for dry rock and creekbeds and things. With no doors its great to be able to see where your wheels are and what the car is doing and when you turn your headlights off your navi can see where everything is and give accurate direction.
I'm planning to have 4 LED reverse/work lights under mine, front back and either side. Plenty of light.
Post Posted: Mon Apr 23, 2012 7:18 pm
I'd suggest that SierraDan is definitely someone who drives stuff where rock lights would be a huge benefit. There arent many people who regularly drive that sort of terrain.
Post Posted: Mon Apr 23, 2012 7:34 pm
With out a navie - useless
With a good navie - brilliant
Post Posted: Mon Apr 23, 2012 7:37 pm
I even only use them on rock. Seeing as they are ROCK lights :lol:
Pretty pointless to have lights under your car if you've driving along a track that requires no planning or direction.
Post Posted: Mon Apr 23, 2012 7:48 pm
yeah exactly, as for the mud issue, it hasnt rained here since jesus was in nappies so its not too much of an issue
Post Posted: Mon Apr 23, 2012 7:56 pm
i've found turning off my headlights (or asking the vehicle im spotting to turn theirs off) does a far better job in helping my spotter guide me at night, as they're not blinded by the headlights in the first place... then as steve said - good torches go a LONG way on a night run.
The other thing to consider with rock lights, is you need to keep them clean - which means doing some mud before hitting the rocks isnt going to be ideal.
Post Posted: Mon Apr 23, 2012 8:22 pm
I find side lights to be indisensible, especially at night in the hills.
Can avoid dropping into ditches on tight turns,
as headlights only point straight ahead.
These are elcheapo super crap 55watt driving lights.
Also good for spotting house numbers etc.
Post Posted: Mon Apr 23, 2012 8:30 pm
another option that i reckon would go alright would be halogen (or LED replacement fittings) downlights, theyre cheap, throw out plenty of light, sealed globe, 50 watts
i have one in my back bumper as a reversing light and its bright as
LED strips or something would be my choice i reckon
Post Posted: Mon Apr 23, 2012 9:00 pm
just found these, might have to order a couple
http://www.ebay.com/itm/Bulb-Waterproof ... 047wt_1270
Post Posted: Mon Apr 23, 2012 10:03 pm
those strips are bright i did mine the same i put it in clear pipe and silicooned the ends
josh AKA Bazook
Post Posted: Tue Apr 24, 2012 8:54 am
love the side light idea. saw switches for them at customrockers and was wondering what the benefit would be, but it kinda makes sense when i think about it. 360 degree lighting
totally agree with Steve's opinion on rocklights, and can see the advantage of Dan having them, shit just look at his avatar pic and you can see why.
but for anyone else, a decent torch in the hand of the guide would be enough.
MY BUILD THREAD HERE!!!!!
Vehicle: '07 Auto Jim - Black
Post Posted: Tue Apr 24, 2012 10:51 pm
tanshi wrote:
These are the same as the ones that I have gone for, but I went for the plastic ones (shown in the second post of your link (mine are white)), the reason being is the metal ones had the wires coming out from LEDs which I didnt like. Otherwise they are the same, and a very bright light indeed.
For $26 (delivered) you can have 20 squares each containing 4x5050 SMD LEDs and consuming ~1.4W each (Link). So for 11.2W (8 total, 1 LED at the front and rear of each wheel) you'll achieve the same desired result as consuming 330W. Also, since they come as 20, I've installed 2 inside as a rear boot light (almost too bright to use), and 2 underneath the bonnet for an engine light. Will have 8 left over after I've done all that, so in terms of value for money I cant see them being beaten.
I have these lights, stripped them out and put 3UP XML 10W LEDs inside each of them, 4 in total, and using them as spotlights. For the price, the casing is fantastic. I'd post a link to my buildup but the pictures are dead so theres no point.
Vehicle: '94 suzuki maruti
Post Posted: Wed Apr 25, 2012 8:40 am
i copied atari's idea with the led strips underneath the car... i havent really needed to use them while 4wding much yet, however i find its perfect for airing up/down at night, and i can see under the car properly to do post-trip damage checks before driving home at night. also, put the car on the edge of the campsite, it gives out enough light to just see the ground about 10 metres either side. plus, the amount of power it uses it could be left on overnight and still be able to start the car the next day.
Post Posted: Wed Apr 25, 2012 9:38 pm
http://www.bigjimny.com/index.php/forum ... uild-guide
i found this that you posted, and im very interested in making a few of these up, do you still have the pics that you could upload again, or could you take some pics of the finished product and night time pics :D
do you reckon the ones i posted will be any good as a spotlight or dont bother and just make some the same as yours
i do love the sound of 12,000 lumens :twisted:
Post Posted: Wed Apr 25, 2012 10:29 pm
I plan to build those into my bulbar when I build that, I've even got 2 lights damn near identical to those! 8O
Anyone know the legalities of these?
Post Posted: Wed Apr 25, 2012 10:33 pm
legalities? for what? the fitment location or their use?
Post Posted: Wed Apr 25, 2012 10:35 pm
I think "work lights" are legal,
as long as they can be switched off,
but its just my interpretation of Vic laws.
Users browsing this forum: No registered users and 244 guests
