Print view
Previous topic | Next topic
| Author |
Message |
zukmeista
Joined: Sun Mar 22, 2009 10:30 pm Posts: 1273 Location: Whangarei,N.Z.
 Posted: Wed Apr 25, 2012 4:37 am |
ZookFan wrote: tanshi wrote: to add to this, considered a china air locker ? almost as cheap as a lock right and saves the arguments  x2  But then you need an air compressor etc. The best thing about lockrights IMO is the simplicity, no hole drilled in your diff, no air lines to get ripped off, no wiring to be done and BEST OF ALL, You can't forget to turn it on
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Wed Apr 25, 2012 7:54 am |
zukmeista wrote: ZookFan wrote: tanshi wrote: to add to this, considered a china air locker ? almost as cheap as a lock right and saves the arguments  x2  But then you need an air compressor etc. The best thing about lockrights IMO is the simplicity, no hole drilled in your diff, no air lines to get ripped off, no wiring to be done and BEST OF ALL, You can't forget to turn it on  All valid points. But you can't turn auto lockers OFF.
_________________ mlm
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Wed Apr 25, 2012 10:29 am |
zukmeista wrote: ZookFan wrote: tanshi wrote: to add to this, considered a china air locker ? almost as cheap as a lock right and saves the arguments  x2  But then you need an air compressor etc. The best thing about lockrights IMO is the simplicity, no hole drilled in your diff, no air lines to get ripped off, no wiring to be done and BEST OF ALL, You can't forget to turn it on  China lockers come with the compressor so it's not an added cost, the install may be slightly more involved but with correct routing of the air lines that won't be a problem. If you forget to turn a locker on you will realise pretty quick if you are doing tracks that require them.
slowsierra
Joined: Sat May 23, 2009 11:30 pm Posts: 415 Location: Greenbank, QLD
Vehicle: 89'SWBsierra&84'LWBsierra
 Posted: Thu Jun 21, 2012 12:41 pm |
i just brought a Sparton locker still not 100 per cent which diff i will go Front or rear. but would anyone be interested in helping me install it and set it up properly. i live in greenbank QLD beers provided. thanks greg
SierraDan
 Posted: Thu Jun 21, 2012 2:01 pm |
Without chromos I'd put it in the back diff.
Users browsing this forum: No registered users and 16 guests
