It is currently Thu Oct 22, 2026 7:47 pm
Vehicle: Nl pajero Lwb, 98 jimny
Post Posted: Mon Apr 23, 2012 2:59 am
Ok I own a 98 Jimny and wish to fit an XROX bar to it, the manufacturer says will fit 05+ but not sure about 98? Are they the same mounting point wise?
Post Posted: Mon Apr 23, 2012 5:56 am
It will fit. You just need to knock off some little tabs on the front of the chassis rails from memory.
Post Posted: Mon Apr 23, 2012 11:24 am
Ok thanks as they told me of I modify the bar will void warranty on it etc which I think is crap when paying over 1k for a bit of steel
Post Posted: Mon Apr 23, 2012 11:53 am
I wouldn't buy another xrox bar :wink:
Vehicle: 2011 Jimmy
Post Posted: Wed Apr 25, 2012 1:45 am
you wouldn't? why's det?
Post Posted: Wed Apr 25, 2012 4:22 pm
I thought you liked your XROX
Post Posted: Wed Apr 25, 2012 6:28 pm
he does now :lol:
Post Posted: Wed Apr 25, 2012 6:46 pm
I do like It! What I don't like is the final finish on the bar, the hoop, and the over all construction of the bar mounts. With a bit of chopping and welding the bar is much bettera ;)
Post Posted: Wed Apr 25, 2012 7:44 pm
uh?? :?
Post Posted: Thu Apr 26, 2012 9:49 pm
Big silly hoop
Big silly hoop goneski
:lol:
Other thing's i did were make the chassis mount's a better 'fit' so there was less movement on them, chopped 20mm of the ends of the wing's on the lower and upper toobe's( stop tyres rubbing), then welded steel caps on the end tooobes because the bar normally comes with little push in caps that always come out and then you end up with mud&shit in the toobes. I also cleaned up some of other welds and cut of the tabs for the spotties that go in the wing's :peaceout:
Vehicle: 2011 Jimmy
Post Posted: Fri Apr 27, 2012 1:20 am
that actually look a balls load better
Vehicle: 2004 Jimny 1.6
Post Posted: Wed Apr 03, 2013 8:22 pm
I like the big silly hoop. I'm actually buying one of these this sat. Looking forward to it
Vehicle: Jimny 2014
Post Posted: Mon Oct 20, 2014 2:01 pm
Hi there, Love the look of this beast. Can i ask what size wheels and offset you are running?
Users browsing this forum: No registered users and 160 guests
