It is currently Fri Nov 13, 2026 9:45 am
Vehicle: 2003 Jimny Auto
Post Posted: Wed Apr 25, 2012 8:23 pm
Hey all
I was wondering if I can change the wheels on my 6x4 box trailer to be the same as my Jimny.
I know nothing about trailer hubs... can you just buy a set of trailer hubs with the correct stud pattern?
Ebay was no help...
Post Posted: Wed Apr 25, 2012 8:34 pm
Dr_Snapid wrote:
Hey all
Ebay was no help...
I think F100 hubs are same pattern.
Sierras use them.
Lots of trailer places sell them.
You could put axle under the springs if it needs to be higher.
Post Posted: Wed Apr 25, 2012 8:35 pm
PS trailer topic has a lot of helpful info
http://auszookers.com/forum/viewtopic.php?f=17&t=8052
Post Posted: Wed Apr 25, 2012 8:36 pm
yea just buy f100 hub kit to fit your axle.
Post Posted: Wed Apr 25, 2012 8:37 pm
Yes you can mate, i changed the hubs on my pod trailer to f100 hubs so i have same rims and tyres allround.
I highly recommend these guys http://www.satrailer.com.au/ but i'm sure someone closer to you could do the same.
I rang them in the morning, they checked to make sure they had some f100 hubs in stock and what bearings i was running on the trailer.
I went straight there, whilst i was paying for them they pressed in the bearings and all greased up. 8)
Post Posted: Wed Apr 25, 2012 9:13 pm
Thanks everyone!
So just to clarify.. f100 as in the ford f100 trucks? My suzuki has the same stud pattern as those behemoths?
I'll ask my local auto parts guy (not supercheap LOL) and see if he can get them for me.
Post Posted: Wed Apr 25, 2012 9:17 pm
I suppose I should also source some Jimny wheels too...
Anyone got 2 or 3?
Post Posted: Wed Apr 25, 2012 9:18 pm
Dr_Snapid wrote:
Thanks everyone!
That is correct.
Also same as lada niva, some jeeps, some dihatsus and off course Vitaras and Sierras.
Post Posted: Thu Apr 26, 2012 9:45 am
i have some stock jimny rims laying around!
yes ftruck and broncos run same pat as suzuki! strange hu
Post Posted: Thu Apr 26, 2012 2:33 pm
Anyone got 2 or 3?
Ive got two 15"x8" ex f100 rims if you want em $20 and come get them, maybe a little far though
Just take one of your hubs off and down to your local trailer shop, from memory there are two main bearing types, ford and something, probably holden, but anyway they get you sorted
Vehicle: chick magnet coily
Post Posted: Thu Apr 26, 2012 5:49 pm
ford and holden
when in doubt... HOLD IT PINNED!!! :)
Post Posted: Thu Apr 26, 2012 6:19 pm
thx guys I just arranged a full new set of rims for the jimny with tyres so i'll have plenty of spares.
I wonder if anyone knows the load ratings of the rims though? My dad has a camper trailer that's pretty heavy and it has 14inch tyres. It wouldnt fit big wheels but maybe the jimny 15s would be ok.
Post Posted: Fri Apr 27, 2012 1:53 pm
Dr_Snapid wrote:
Thanks everyone!
What is funny is that people bag suercheap but with many parts including trailer hubs they get them from the same manufacturers as every other auto parts place does, however because they have buying power they can sell them to you cheaper. I have recently put new hubs on a jetski trailer for a mate, he got them from supercheap, they were the same and in same packaging as ones I bought from a trailer specialist at Brendale, his were $15 cheaper for the pair.
Post Posted: Sat Apr 28, 2012 10:10 am
That's great to know. Do you think SC might have what I need?
Post Posted: Sat Apr 28, 2012 11:33 am
Last time I was in a SuperCheap they had F100 hubs.
Post Posted: Sat Apr 28, 2012 9:18 pm
Does this look right?
http://www.supercheapauto.com.au/online ... escription
I wish it showed the stud pattern specs
Post Posted: Sat Apr 28, 2012 9:25 pm
Aha! http://www.arkcorp.com.au/Products/Hubs ... k.tpl.html
That page shows the stud pattern is Stud PCD 5x114.3mm
But my understanding is Jimny stud pattern is PCD 5x139.7.
But i'm closer...i'm learning...
Post Posted: Sun Apr 29, 2012 7:54 am
No
No
These listings are for Ford Falcon stud pattern.
The pattern you need will be labelled as F100. The hubs SCA carry for F100 will probably not have the correct bearing size/spacing for your existing axle.
You'll need a specialist trailer parts supplier to get F100 with the correct bearing size/spacing to match your axle.
When I built my original trailer you could only fit F100 hubs to a large diameter axle but as others have mentioned in this thread the hubs are now available to suit other bearing configurations.
In Brisbane I use Vehicle Components at Geebung.
http://www.vehiclecomponents.com.au/
Check out row F
Post Posted: Sun Apr 29, 2012 5:18 pm
I think i'll follow these simple instruction to convert it:
Wait till have my extra set of jimny wheels.
Throw 2 of them in the trailer.
Pull up at the local trailer place and say 'please change my hubs so the trailer takes these wheels, call me when it's ready'
Get on with my life.
I expect they will look at the state of the axle and springs and want to replace the lot, though. They certainly look rusty.
Post Posted: Sun Apr 29, 2012 5:25 pm
Only looked under my trailer today
This is what I saw 8O
Post Posted: Sun Apr 29, 2012 6:19 pm
Axle will be fine but could do with a coat of paint.
New springs are only $40 or so each.
Post Posted: Sun Apr 29, 2012 8:09 pm
Thanks Want33s
What do you think I should look for when deciding if the springs need replacing? Should they be replaced if they have rust, or should I look for other signs of decay before writing them off?
Post Posted: Mon Apr 30, 2012 6:58 am
From what I can see of those springs they look pretty good. Mine had a lot more, wire brushed them, oiled them... all good.
So long as the metal hasn't eaten away and they're not rusted solid they should still be fine. Of course you have to make that call :wink:
Post Posted: Wed May 02, 2012 7:28 pm
I am trying to get the time and the weather to coincide so I can take a closer look... it's either raining, or dark, or i'm working...
Post Posted: Wed May 02, 2012 9:19 pm
I stopped in at Vehicle Components today and asked if they had F100 hubs for differing bearing configurations.
He said yes and we agreed that I'll bring a hub in to confirm.
Post Posted: Thu May 03, 2012 6:09 am
That's where I got my hubs for my trailer. Drilled the blank hubs while I waited. :P
SS
Post Posted: Thu May 03, 2012 7:04 am
They're pretty good there. One stop trailer parts shop.
Post Posted: Thu May 03, 2012 10:35 pm
Shame it's north side. I'll be kinda up that way in a few weekends but the financial complainer/controller will be present also.
I also just realised that in my pics the trailer seems to be 5 stud. I really ought to make sure it doesnt already have the right pattern, shouldnt I?
It looks too small though...
Post Posted: Fri May 04, 2012 6:58 am
Highly unlikely it will be the same. Will probably be a Ford Falcon or Holden stud pattern as they are the most common. Show us a pic of the wheel and someone will probably know what it's off.
Users browsing this forum: No registered users and 23 guests
