It is currently Tue Nov 03, 2026 12:28 pm
Vehicle: 2008/09 Jimny Sierra
Post Posted: Fri May 04, 2012 7:53 pm
its happens occasionally when i hit a bump. i hear what appears to be the side door shudder as if its loose. anyone else have this problem. I also had it in my 2001 soft top
"You Just Got JIMMERED" Jimmer Freddette
Post Posted: Fri May 04, 2012 9:06 pm
Sure its not a blown shockie?
Post Posted: Fri May 04, 2012 9:20 pm
a hundred percent... its just like the doors hinge isnt tight enough or somthing its just a slight annoying shudder
Post Posted: Fri May 04, 2012 10:43 pm
Probably just the door striker needs adjusting.
Post Posted: Fri May 04, 2012 11:41 pm
My 05' jimny had a simular problem. i talked to my panel beater and he said give this ago. mark where the door lock hanger is, loosen it off a tiny bit then give it a little tap back. not to sure if its the same problem. But it worked for me.
Vehicle: 06 Jimny VVT
Post Posted: Sat May 05, 2012 6:10 am
OUr o6 Jimny as well. Doors rattled over every bump. Adjusted the striker in a little and fixed. The only issue is you have to adjust them in a fair way to stop the noise and sometimes it tkes 2 goes to shut the door, but beats the rattle...
Post Posted: Sat May 05, 2012 2:10 pm
Off topic - but does any one else have a issue with the rear door banging over bumps? Sound's like the car is going to fall apart over corrugation's :(
Post Posted: Sat May 05, 2012 2:47 pm
I do i try the same thing what i did to the passenger door but dont work i was going to look more in to it but i got bigger problem now
Post Posted: Sun May 06, 2012 4:25 pm
Slam it harder :lol:
Post Posted: Sun May 06, 2012 5:15 pm
Hehe :mrgreen: :mrgreen: :mrgreen:
Post Posted: Sat May 12, 2012 3:47 pm
Bingo!!!!
